OSPF and redundant paths
andrewrocks
I'm trying to get a proof-of-concept working, and it almost does except for the final stage.
I'm trying to make a loop of switches so that if one link goes down then all switches can communicate with each other:
Switch A Port 0/48 <-> Switch B Port 0/47
Switch B Port 0/48 <-> Switch C Port 0/47
Switch C Port 0/48 <-> Switch A Port 0/47
All switches are IPServices 3560 PS POE switches.
I am also trying to integrate OSPF with this setup with the following IP details:
Switch A L0 - 172.31.255.1/32
Switch A VLAN1 - 172.1.0.1/24
Switch A 0/47 - 172.31.254.10/30
Switch A 0/48 - 172.31.254.1/30
Switch B L0 - 172.31.255.2/32
Switch B VLAN1 - 172.2.0.1/24
Switch B 0/47 - 172.31.254.2/30
Switch B 0/48 - 172.31.254.5/30
Switch C L0 - 172.31.255.1/32
Switch C VLAN1 - 172.1.0.1/24
Switch C 0/47 - 172.31.254.6/30
Switch C 0/48 - 172.31.254.9/30
I have then configured VLAN1 and ports 0/47-48 to be in the OSPF Area 0 on each switch.
This was all going fine until I brought up Switch C port 0/48 and then I lost all network connectivity and my laptop said the port (on VLAN1 of Switch A) was going up and down every few seconds. Equally the terminal output of switch B said that interfaces were going up and down.
Each switch as Spanning Tree set to PVST.
What have I missed? Is OSPF not supposed to be used in this way? Am I supposed to ensure there are no loops on the network?
Thanks for any and all help. If I have left out any information please ask.
Andrew.
11 Replies 11
Richard Burts
Andrew
How are ports 47 and 48 configured on these switches? Are they in a common VLAN? If we could see config details we might be able to give better suggestions about the problem.
Rick
Rick
I'd love to give you a config output, but the swtiches are at work and I'm at home. I will post them first thing tomorrow.
Ports 47 and 48 are all
no switchport
i.e. I'm using the links between the switches as layer 3 links as in practice these links will be a combination of cross-site fibre and wireless.
Andrew.
Sorry for the delay, the config are
Switch A:
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback0
ip address 172.31.255.1 255.255.255.0
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/47
no switchport
ip address 172.31.254.9 255.255.255.252
interface FastEthernet0/48
no switchport
ip address 172.31.254.1 255.255.255.252
interface Vlan1
ip address 10.20.1.1 255.255.255.0
interface Vlan2
ip address 172.1.0.1 255.255.255.0
router ospf 1
log-adjacency-changes
network 172.1.0.0 0.0.0.255 area 0
network 172.31.254.1 0.0.0.0 area 0
network 172.31.254.9 0.0.0.0 area 0
ip default-gateway 10.20.1.10
ip classless
ip http server
ip http secure-server
ip ospf name-lookup
snmp-server community public RO
control-plane
Switch B:
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
interface Loopback0
ip address 172.31.255.3 255.255.255.0
no switchport
ip address 172.31.254.2 255.255.255.252
no switchport
ip address 172.31.254.5 255.255.255.252
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
ip address 10.20.1.3 255.255.255.0
interface Vlan2
ip address 172.3.0.1 255.255.255.0
router ospf 1
network 172.3.0.0 0.0.0.255 area 0
network 172.31.254.2 0.0.0.0 area 0
network 172.31.254.5 0.0.0.0 area 0
ip classless
ip http server
Switch C:
no aaa new-model
ip subnet-zero
ip routing
no file verify auto
interface Loopback0
ip address 172.31.255.2 255.255.255.255
interface FastEthernet0/3
interface FastEthernet0/46
no switchport
ip address 172.31.254.10 255.255.255.252
no switchport
ip address 172.31.254.6 255.255.255.252
interface Vlan1
ip address 10.20.1.2 255.255.255.0
interface Vlan2
ip address 172.2.0.1 255.255.255.0
router ospf 1
network 172.2.0.0 0.0.0.255 area 0
network 172.31.254.6 0.0.0.0 area 0
network 172.31.254.10 0.0.0.0 area 0
ip default-gateway 10.20.1.254
ip classless
ip http server
Andrew
Thanks for providing additional information. There are several discrepancies between what you give in the original post and what is in the config. Your description says that the loopbacks are to be /32 but switches And B have /24 on their loopbacks. And some of the addressing you give for ports 47 and 48 does not match with the description. Switch A port 47 should be .10 but is configured as .9. Switch C port 47 should be .6 but is configured as .10 and port 48 should be .9 but is configured as .6. Your description talks about just VLAN 1 but the config shows VLAN 1 and 2.
But I am not sure that these descrepencies are causing your basic  problem. The description of interfaces going up and down sounds like an issue with spanning tree. And we do not have enough information to analyze a spanning tree issue.
Rick
Rick
You're absolutely right, I seem to have mixed up my config a bit and got some switches backwards. However, the only stuff I've taken out of the config files is the ports with no information / settings so all the spanning tree settings are there.
Everything I've read about ospf says this should work and none of it talks about spanning tree, I feel like I'm missing something.
Thanks for your help.
Hard to say without knowing exactly what you see. Can you please paste all logs, TS you havde done so far to understand the problem itself.
For what I have now just after screening config, pls advies why you have different default GW in Vlan1:
- on C: ip default-gateway 10.20.1.254
- on A&B ip default-gateway 10.20.1.10
- your OSPF is not configured to carry VLAN1 and VLAN2 networks it only cares about p2p subnets thus it does not help you with connectivity in VLANs
- How do you also connect to these switches? console, vlan1, vlan2, etc
So please send following to understand what you are doing, see now and want to get:
- diagram (including your PC and default GW)
- logs you see during the problem
- sh cdp nei (from each switch)
Nik
HTH,
Niko
ebarticel
Level 4
Level 4
A suggestion is try removing "ip default-gateway...." commands and replace them with a default static route on switches.
Hope it helps
Eugen
Hope it helps
Eugen
I think that ended up in there from the express setup screen. The office is closed today for bank holiday but I shall try this first thing tomorrow - thanks.
I shall also check that the switch config matched the diagram I've made as there are clearly discrepancies.
Finally "
The idea is that these switches will be split between sites so I don't want Layer2 traffic going between vlans, only layer 3. Is this not the recommended design?
Thanks for your input, it's very much appreciated.
Andrew.
Aileron88
This won't be a spanning-tree issue, as we are solely relying on layer 3 paths between the switches. Also, the 'ip default-gateway' command offers layer 2 functionality, i.e. when 'ip routing' is not enabled.
I would configure your devices EXACTLY how you have explained in the first post, paying close attention to the configuration of the VLAN 1 interface IP address and mask.
Would also be worth taking the 'ip ospf name-lookup' command off in the lab scenario, this will make your 'sh ip ospf nei' take an age to complete.
In response to your last reply, keep VLAN traffic local to the site as you are currently doing. You will still need to ensure the subnets on which your hosts sit are advertised in to OSPF so the other devices have reachability to these subnets.
Adam
Ok, I never found out what the problem was with this. I just cleared out all my settings, did them again and now it works.
There must have been a mistake somewhere, but I couldn't work it out.
Thanks for all the suggestions.
Andrew
I am glad that you got it to work correctly when you went back and did it over again with a fresh start. Thanks for posting back to the forum and letting us know that when you did the setup over again that it now works as expected.
Rick
Rick
