OSPF authentication still works without matching key?
vincehgov
Hi. I have two routers setup - R2 and R8.  I have message-digest configured on both routers' ospf processes.  On R2, I have the message-digest-key statement with the key 'hello'.  On R8, I only have the 'ip ospf authentication' statement.
Theoretically, these two routers should not be adjacent right?  However, it looks like its still forming adjacencies and exchanging routes.
How is this possible?
R8#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.40.1.2         1   FULL/BDR        00:00:39    192.168.2.1     FastEthernet1/0
R8#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
O       10.40.1.0 [110/2] via 192.168.2.1, 00:17:11, FastEthernet1/0
C    192.168.2.0/24 is directly connected, FastEthernet1/0
R8#
R2:
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
ip ospf message-digest-key 1 md5 7 011B03085704
router ospf 1
log-adjacency-changes
area 0 authentication message-digest
network 192.168.2.0 0.0.0.255 area 0
R8:
interface FastEthernet1/0
ip address 192.168.2.2 255.255.255.0
router ospf 1
area 0.0.0.0 authentication message-digest
network 192.168.2.0 0.0.0.255 area 0.0.0.0
Edison Ortiz
If you remove 'ip ospf authentication' from R2, it will use the message-digest key and the adjacency will break.
At the moment, it's using simple password with a null password (type 0)
You can verify the current authentication method with the command 'show ip ospf interface'
Edison
Edison Ortiz
Edison
ahh.. so the ip ospf authentication takes precedence and a null password is used by default if not specified.
Got it.
Thanks!
Vince
The OSP authentication type can be configured at the area level or at the interface level and then it takes precedence over the area authentication.
So here area wise you ask authentication type 2 but at the interface level you ask for type 1 and as you ask for same type on each router then the adjacency comes up. On R2 you entered the md5 key but as you have type 1 authentication it is taken into effect.
So I think you are using type 1: simple text authentication and not null( type 0) which means no authentication.
Regards.
Alain.
