OSPF auto-cost reference-bandwidth - best way to change it on multiple devices
smailmilak
Level 4
Level 4
we are installing new gear with 100G links and because of auto-cost reference-bandwidth 10000 we have to change it to 1000000 (1Tbps).
The problem is that we have over 200 devices under OSPF area 0 with multiple links on each.
One way is to connect to every device, check the cost, add it under the interface and after that change auto-cost. After every device is reconfigured we can remove that statically assigned cost.
Is there a better, faster way to change it?
I wonder why Cisco has no implemented a way to change auto-cost on every device at the same time.
e.g. auto-cost reference-bandwidth "at 23:00"
We have IOS, IOS-XR and IOS-XE in out network.
andrewswanson
Level 7
Level 7
have you looked at using tcl scripts? below script will set ospf ref bw to 5656 for ospf process 1 - kron job will run the script once at 21:58
hth
Andy
tclsh
puts [open "nvram:ospf-cost.tcl" w] {
ios_config "router ospf 1" "auto-cost reference-bandwidth 5656"
tclquit
config t
kron policy-list ospf-cost.tcl
cli tclsh nvram:ospf-cost.tcl
exit
kron occurrence ospf-cost.tcl at 21:58 oneshot
andrewswanson
Level 7
Level 7
hth
Andy
tclsh
tclquit
config t
exit
tcl is a good way to do this, thanks for the script.
I can try to convince our customer to go with TCL.
