OSPF configuration
rouzbehta
Level 2
Level 2
Hello all,
I am so confused on a network configuration, I attached a pdf file which shows a network I am going to build.
If some one can help me and give me the configuration I really appreciate it.
Best Regards,
Sorry for this but no problema there is a way.
First you need to check whether your switch support ospf or not  if yes you can try below config to give IP address
on vlan interface
----------:Router:--------------
Router#
interface FastEthernet6/0.101
encapsulation dot1Q 101
ip address 189.189.189.1 255.255.255.252
no snmp trap link-status
end
---------: Switch :-------------
vlan 101
name TEST1
interface Vlan101
ip address 189.189.189.2 255.255.255.252
no shut
end
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 101
switchport mode trunk
end
same way you can configure other end of switch.
Mahesh
8 Replies 8
Mahesh Gohil
Level 11
Level 11
Please find config as per the instruction given in diagram
RTR2
int fa0/0
no ip address
no shut
int fa0/0.10
encapsulation dot1q 10
ip address 10.10.10.1 255.255.255.128
no shut
router ospf 1
router-id 2.2.2.2
network 10.10.10.0 0.0.0.127 area 0
network 2.2.2.2 0.0.0.0 area 0
network 172.31.0.0 0.0.255.255 area 0
RTR1
int fa0/0
no ip address
no shut
int fa0/0.11
encapsulation dot1q 11
ip address 10.10.10.129 255.255.255.128
no shut
router ospf 1
router-id 1.1.1.1
network 10.10.10.128 0.0.0.127 area 0
network 1.1.1.1 0.0.0.0 area 0
network 192.168.0.0 0.0.255.255 area 0
Switch:
int fa0/1.10
ip address 10.10.10.2 255.255.255.128
int fa0/2.11
ip address 10.10.10.130 255.255.255.128
router ospf 1
Please let me know if you face any problem with above config
Mahesh
Dear Mahesh,
In the switch I can't define encapsulation dot1q 10 on the suninterface fa0/1.10, switch doesn't have this ability, is it because IOS issue or the switch problem?
you can only create subinterfaces on Router interfaces not on switchinterfaces.
Rgds Martin
on vlan interface
Router#
end
vlan 101
name TEST1
interface Vlan101
no shut
end
end
Mahesh
Thank you dear Mahesh, it was correct and works fine
Jigar Dave
Level 6
Level 6
Hello rouzbehta,
please clarify the switch you are using is Layer 2 or layer 3?
in layer 3 switch we can assign IP address but in layer 2 switch we can't.
That will help
Best regards,
Jigar Dave
as it is asked for an ospf peering with the switch it must be a L3 switch.
I decided to use routed ports but you could have used SVIs instead for VLAN10 and VLAN11.
On each router f1 interface must be connected to a switch trunk link.
I attached the config that I think should do what you want.
Regards.
Alain.
  On a normal switch you cannot use subinterfaces to trunk .  You need to setup layer 3 svi's  and then setup trunking on the link .
