Storm-Control
pablo.arcelcr
Level 3
Level 3
Hi.
We setup the following in a interface trunk:
storm-control broadcast level 5.00
storm-control action shutdown
storm-control action trap
spanning-tree guard loop
Aster a few days the interface went down.
Do you know how can we determine what cause the issue?
Where o What we can check?
Julio E. Moisa
I think there is no proper value for the storm control, it can depend of traffic passing through your network. Is your port as blocking or Link down? it can be verified using show storm-control
You could use storm-control action trap only in order to verify the alerts and if it is required you can shutdown the port manually.
You could use the command line after business hours:
debug storm-control statistics
debug storm-control detection
These links could be useful
http://packetlife.net/blog/2008/nov/27/storm-control/
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/best/practices/recommendations.html#wp1044029
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
