ospf database issue
andretimoll
Level 2
Level 2
Hi Guys
I have run into a problem which i just dont understand.
If i perform a show ip route i can see a route learnt via ospf in the routing table
cisco#sho ip route 10.231.27.254
Routing entry for 10.231.27.0/24
Known via "ospf 100", distance 110, metric 13001, type intra area
Last update from 172.31.38.12 on Tunnel10, 00:09:58 ago
Routing Descriptor Blocks:
* 172.31.38.12, from 172.31.39.7, 00:09:58 ago, via Tunnel10
Route metric is 13001, traffic share count is 1
But if i search the ospf database for it i cant locate it..
cisco#sho ip ospf database | i 10.231
cisco#
Could someone explain exactly what is occuring? I suspect im missing something obvious.
Andre
5 Replies 5
Andre,
The command "show ip ospf database" only shows an LSA summary of the OSPF database. 10.231.27.0/24 is an an intra-area route so would be derive from the information in the LSA type 1 and type 2. Try "show ip ospf data" and "show ip ospf net" to find the information about this subnet.
Andre,
Sorry. I meant "show ip ospf da router" and "show ip ospf data net".
Giuseppe Larosa
Hello Andre,
this is an intra area route so the subnet 10.231.27.0 can be part of a router LSA that has a tag = OSPF router-id
try
sh ip ospf database adv-router 172.31.38.12 [detail]
Hope to help
Giuseppe
Hi Giuseppe
If I try that command I still can't see that route in the database, i haven't got the option for detail.
Am I not right in assuming theses intra area routes must be in the database to be installed in the routing table?
cisco#sh ip ospf database adv-router 172.31.38.12 ?
| Output modifiers
OSPF Router with ID (172.31.39.233) (Process ID 100)
Router Link States (Area 1)
Link ID ADV Router Age Seq# Checksum Link count
172.31.38.12 172.31.38.12 280 0x800180E9 0x001704 42
Summary Net Link States (Area 1)
10.252.1.0 172.31.38.12 783 0x8000065B 0x000FC5
10.252.2.0 172.31.38.12 783 0x8000065B 0x0004CF
10.252.3.0 172.31.38.12 783 0x8000065B 0x00F8D9
10.252.4.0 172.31.38.12 784 0x8000065B 0x00EDE3
10.252.5.0 172.31.38.12 784 0x8000065B 0x00E2ED
10.252.6.0 172.31.38.12 784 0x8000065B 0x00D7F7
10.252.7.0 172.31.38.12 784 0x8000065B 0x00CC02
10.252.8.0 172.31.38.12 784 0x8000065B 0x00C10C
10.252.9.0 172.31.38.12 784 0x8000065B 0x00B616
10.252.10.0 172.31.38.12 784 0x8000065B 0x00AB20
10.252.254.0 172.31.38.12 783 0x800044F8 0x002853
172.31.38.1 172.31.38.12 784 0x80001022 0x00E434
172.31.38.2 172.31.38.12 784 0x8000065B 0x008662
172.31.38.16 172.31.38.12 784 0x8000065B 0x00F9E6
172.31.38.74 172.31.38.12 784 0x80004F3D 0x000A6C
172.31.38.75 172.31.38.12 784 0x8000065B 0x00A9F5
Summary ASB Link States (Area 1)
172.31.38.1 172.31.38.12 783 0x80001022 0x00CC4C
172.31.38.2 172.31.38.12 784 0x8000065B 0x006E7A
The subnet I am trying to get to should be a network LSA as it is the LAN subnet on another router in area 1. The network setup is all the remote sites are in area 1 which is connected to area 0. Could this setup be the reason why the ospf database looks incomplete??
Hello Andre,
the net you are looking for is inside the router LSA data structure
172.31.38.12 172.31.38.12 280 0x800180E9 0x001704 >>>>42
the link count is 42 so you can understand that here multiple links, and multiple ip subnets are contained.
try
sh ip ospf database router 172.31.38.12
the net is clearly in the database but it can be difficult to find it because a single router lsa exist for each OSPF node.
if the net is associated to a broadcast segment the DR router will generate a Network LSA.
From your output we can understand that router 172.31.38.12 is not the DR for the enquired subnet.
As suggested by Harold you can also use
sh ip ospf database network
this should return some info
Hope to help
Giuseppe
