OSPF default
cisco.anubhav
Level 2
Level 2
hi,
i have a trinagle network     B and C are connected to A ,a has static default route to isp,while ospf is configured on all three ,b and c does not generate acandidate default routein theirrouting table.Here all links are 34 mb,i.e.
        A
34  /     \34
   B--------C
      34
kindly help.
2 Accepted Solutions
cadet alain
to generate a default route into OSPF you must use the command default-information originate.
Regards.
Alain
John Blakley
Are you asking how to generate a route for ospf to pass to neighbors B and C? If you have a static default on A, under A's routing process type in "default-information originate".
HTH,
John
HTH, John *** Please rate all useful posts ***
cadet alain
Regards.
Alain
John Blakley
HTH,
John
