OSPF Doubt
antonyice1
Community Member
I have two 6509 Core switches in my Datacenter and is running HSRP between them.It has got a couple of Vlans and Vlan interfaces created on it.It also has OSPF created for the same Vlans on the CORE switch .Can somebody explain to me what is the need of this OSPF.Is this for the communication between the CORE Switches ?
Please advice.
5 Replies 5
mahmoodmkl
Level 11
Level 11
Do u have any L3 link between the core switches..?
if not i dnot think its of any use.
Mahmood
What do you mean by that ? The Configuration is given below.Please verify.
vlan 311
name FWSM_ADM_OUT
vlan 312
name FWSM_ADM_IN
vlan 321
name FWSM_DC_OUT
vlan 322
name FWSM_DC_IN
interface Loopback0
ip address 172.10.250.1 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Port-channel1
description ++++ L2 Link to Core 2 ++++
switchport
interface Vlan300
description ++++ Connetced to NetScreen ++++
ip address 172.10.2.3 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
standby 3 ip 172.10.2.5
standby 3 timers 1 3
standby 3 priority 110
standby 3 preempt
standby 3 authentication md5 key-string 7 06350A22595C0C31362522
standby 3 name TIER1FW
interface Vlan311
description ++++ FWSM Admin Out Interface ++++
ip address 172.10.2.10 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
standby 1 ip 172.10.2.9
standby 1 timers 1 3
standby 1 priority 110
standby 1 authentication md5 key-string 7 03375E08131D24647D3B29
standby 1 name FWSMADMOUT
interface Vlan321
description ++++ FWSM DC OUT Interface ++++
ip address 172.10.2.18 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
standby 2 ip 172.10.2.17
standby 2 timers 1 3
standby 2 priority 110
standby 2 preempt
standby 2 authentication md5 key-string 7 0538030C345E4B212A3727
standby 2 name FWSMDCOUT
router ospf 1
router-id 172.10.250.1
log-adjacency-changes
auto-cost reference-bandwidth 100000
network 172.10.2.10 0.0.0.0 area 0
network 172.10.2.18 0.0.0.0 area 0
network 172.10.250.1 0.0.0.0 area 0
Hello Antony,
from your configuration OSPF is used at least to exchange routing information about each switch's loopback ip address.
Hope to help
Giuseppe
Also, as the two other network statements are from the two VLANs going to the FWSM, it's a possibility that you exchange routing informations with the FWSM. This of course only if OSPF is configured on the FWSM as well.
antonyice1
Community Member
No , OSPF is not configured on the FWSM .My doubt is something like this what will happen if OSPF was not configured since I could see lot of static routes on the CORE Switch.
Thanks for you advice.
