OSPF error: Dead timer expired
Ilya Semenov
Level 4
Level 4
Hello, everybody!
I have two routers, which I want to bind with OSPF. The problem is I can't made them to be neighbors for each other. I receive the following error message on router:
sz-novg-derzh-2#
Oct 25 09:59:19.023: %OSPF-5-ADJCHG: Process 1, Nbr 172.18.245.80 on GigabitEthernet0/0.1 from LOADING to FULL, Loading Done
Oct 25 09:59:22.051: %OSPF-5-ADJCHG: Process 1, Nbr 172.18.245.80 on GigabitEthernet0/0.1 from FULL to DOWN, Neighbor Down: Dead timer expired
Oct 25 09:59:27.191: %OSPF-5-ADJCHG: Process 1, Nbr 0.0.0.0 on GigabitEthernet0/0.1 from ATTEMPT to DOWN, Neighbor Down: Dead timer expired
Oct 25 09:59:29.019: OSPF-1 EVENT: service_maxage: Trying to delete MAXAGE LSA
sz-novg-derzh-2#
This is show int for the interface at router sz-novg-derzh-2:
interface GigabitEthernet0/0.1
encapsulation dot1Q 55
ip address 172.18.25.133 255.255.255.252
ip ospf network non-broadcast (Without this I can't set neighborhood between them cause it says that "wrong network types")
ip ospf dead-interval 3
ip ospf hello-interval 1
This is show int for the interfaces at router r-psk2:
interface GigabitEthernet0/0.55
ip address 172.18.25.134 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf priority 0
interface GigabitEthernet0/0.66
encapsulation dot1Q 66
ip address 172.18.25.245 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet0/1
ip address 172.18.245.80 255.255.255.224
no ip redirects
          no ip unreachables
no ip proxy-arp
ip ospf priority 0
duplex auto
speed auto
Both routers can ping each other.
Hello and dead intervals are same. Then, what could be the problem?
Please, help!  The full show runn for both routers are applied.
Many thanks in advance!!!
8 Replies 8
Guru Mysoruu
Level 4
Level 4
OSPF Neighbors
All of the following fields in an OSPF hello message must match for an adjacency to form:
  • hello timer
  • dead timer
  • area ID
  • authentication type
  • password
  • stub area flag
Note: On multi-access links, adjacencies are only formed between the router and the DR and BDR.
That's interesting.. The default is "BROADCAST" on Ethernet ports, so is this configured as n NBMA somehow?
Can you try putting 'ip ospf mtu-ignore' on the port that is attempting to form a neighbor relationship with the other OSPF network?
Just so I understand this correctly. GigabitEThernet0/0.1 on sz-novg-derzh-25 is directly connected to GigabitEthernet0/0.55 on r-psk2? Is this connect run through any other switches via L2 or just a cable from each switch going into the other?
I'm a little confused as to way, it wouldn't work without 'ip ospf network non-broadcast'. Because as of right, without this on GigabitEthernet0/0.55 it should still be complaning about mismatched network types, and it's a /30 at that.
Hi!
Thank you for your response!
GigabitEThernet0/0.1 on sz-novg-derzh-2 is not directly connected to GigabitEthernet0/0.55 on r-psk2.
1) r-psk2 is connected to 2960 switch
2) There is provider's virtual channel between the 2960 switch and sz-novg-derzh-2 router. For me, it's like direct cable connection from port to port.
You are completely right with this:
I executed "ip ospf network non-broadcast" command for GigabitEThernet0/0.1 interface on sz-novg-derzh-2. The message about mismatched network types disappeared after that, but new one about "Dead timer expired" came...
Are there any solutions for my problem?
Many, many thanks to you!!!
From looking at your configurations it looks like the hello-interval and dead-interval are the same for these two neighbors. On router sz-novg-derzh-2, does the "Dead timer expired" ever start receiving hellos? It's possible, since this goes through a switch (correct me if I'm wrong on that), that spanning tree could by causing some issues, considering on how short the dead timer is.
Thank you John,
you mean, that looking at this
sz-novg-derzh-2#
sz-novg-derzh-2#
it is impossible to understand whether sz-novg-derzh-2 router receives hello from neighbor?
Actually, I think that they establish a very short partnership, because from other router, connected to sz-novg-derzh-2, I can ping remote addresses from network, known by r-psk2, but in a very strange way. For example, I execute ping x.x.x.x -t command and receive countless "Request timed out" but periodically, may be every 2-3 minutes, I receive 5-6 succesful replies and the endless "Request timed out"!!!
May be, I have to increase dead-interval value?
Oops, I have missed something from your previous post - I'll try to run "ip ospf mtu-ignore" command on Monday - at the moment those office is closed.
Many thanks to you!
If you have access to both routers, even if the adjacency goes down then yes. Also if you have syslog setup, you should be able to see that as well, depending on how your trap level is setup.
On your above config, it shows Nbr 172.18.245.80 going from FULL to DOWN, with the reason being Dead timer expired.
From your initial post, I don't see a interface configured on the same subnet..
It sounds like you could possible have a L2 issue somewhere.
The problem was solved.
I have converted trunk port on the switch (between routers) to access.
Then, I deleted the subinterface on the novgderzh-2 router, configured GigaEthernet 0/0 int, and set DEAD-Interval to 15 instead of 3.
Everything works fine now!!!
Many thanks to all the participants of this discussion!
