ospf flapping
redboynono
we find some ospf notification log on our core-switch like below:
Jul 21 07:15:56.167: %OSPF-5-ADJCHG: Process 1, Nbr 202.165.96.216 on Port-channel3 from FULL to DOWN, Neighbor Down: Dead timer expired
Jul 21 07:16:03.227: %OSPF-5-ADJCHG: Process 1, Nbr 202.165.96.216 on Port-channel3 from LOADING to FULL, Loading Done
anyone had seen it before ??
5 Replies 5
Ryan Carretta
Dead timer expired suggests that there were lost hello packets between the two switches. Check to see if the link(s) between these OSPF neighbors is congested and/or if there is (or was) a high-cpu condition on either device.
shiva_ial
hi,
from the output what i could see
is preobelm occured in ospf relationship,
which makes the portchannel down at 15:56
means this neighbor is not reachable from
the router you have taken log.
it was again reachable only by 16:03
in simple, 7 mins no ospf relationship between the router you have taken log and its
neighbor 202.165.96.216
rgds/shiva
Please upload the output of 'show process cpu history' from both devices.
Hello shiva,
are only 7 seconds just the time to rebuild the OSPF adjacency.
Down doesn't mean that the portchannel went down, but refers to ospf neighbor state machine from Full -> down because DEAD timer expired means router was not able to receive ospf hello during last 40 seconds. (with default timer values)
Jul 21 07:15:56.167: %OSPF-5-ADJCHG: Proces(s 1, Nbr 202.165.96.216 on Port-channel3 from FULL to DOWN, Neighbor Down: Dead timer expired
The trouble comes if the event happens many times.
Try to investigate on how much the port-channel is used. A QoS scheduler to protect ospf traffic could be needed if the link is very busy.
hope to help
Giuseppe
thank you all for your replying .
