ospf issue 2way
Mary
Level 5
Level 5
my ospf neighbor today is in 2WAY/DROTHER state,the ospf has running for four years and no issue,  the ospf interface is up/up, but log says : neighbor from 2WAY to DOWN, Neighbor Down: Dead timer expired, what's the possible reason? how to fix
5 Replies 5
You need to provide us more information. How many devices are in the segment? Was there any configuration change? Is the process restarted?
Please provide us: show ip ospf neigh, show run | inc ospf, sh run | sec router ospf, ...
HTH,
Meheretab
HTH,
Meheretab
Yes usually its because no dr/bdr but something would have changed to cause that if it was already working to get stuck in 2 way state
This is how it occurs see the doc for clear explanation
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13683-11.html
that core switch all neighbor become ospf 2 way suddenly, no configuration change, can't figured out why it happens
Could you share part of your config related with OSPF?
HTH,
Meheretab
Julio E. Moisa
Also verify the ospf network type under the interfaces.
Also you can run a: debug ip ospf adj   (recommended after business hours)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
