ospf-nexus 5k
Anukalp S
Hi.. i have been running nexus 5548 and looking for implement ospf. But not sure whether it support advance ospf routing. Pls tell me whether ospf would run on this switch with all its advance features.
Software
  BIOS:      version 3.5.0
  kickstart: version 5.0(3)N2(1)
  system:    version 5.0(3)N2(1)
5 Replies 5
ajay chauhan
Level 7
Level 7
1st thing make sure you have daughter card installed .
2nd thing 5.0.3 supports only ospfv2 so if you dont have plan to run ipv6 you should be good.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/Cisco_n5k_layer3_ucast_cfg_rel_503_N1_1/l3_ospf.html
Ajay
Thanks Ajay, how could i check through cli whether there is daughter card installed in device.
If i use sh invertory what output would it show to verify deaughter card installed.
Yes, show inventory or show module will verify that for you.
Thanks Reza.. but my question is if i excecute sh inven or sh module on switch, what output would display for switch having daughter card installed.
It would show you that you have a layer 3 daughter card (module) installed.
