OSPF ON 3745
intermel2002
I'VE TRIED THE OSPF IP CONFIGURATION ON MY 3745 ROUTER AND IT SEEMS IT'S NOT RUNNING I THEN CHECKED THE DEBUP IP OSPF HELLO AND THE HELLO PACKET JUST DONT COME UP I NEED ASSISTANCE.
cfabeny
You will want to use the "debug ip ospf adj" command for this. Basic things to check are MTU settings on both sides, hello and dead timers and OSPF network types.
Can you post the configurations
Here is a link for troubleshooting OSPF
http://www.cisco.com/warp/public/104/trouble_main.html
HTH, rate if it does
Narayan
