ospf point to point links
carl_townshend
hi all
when talking about ospf point to point, how does it function over a serial interface, does a normal serial e1 interface support multicast? or do you have to manually configure the neighbour?
Giuseppe Larosa
Hello Carl,
you don't need to configure the neighbor until L2 encapsulation is not Frame-Relay.
main interface with FR encapsulation is treated as NBMA and needs the neighor statements or the
ip ospf network broadcast
the type of OSPF network can be seen with sh ip ospf interface type x/y
Hope to help
Giuseppe
mahmoodmkl
Level 7
Level 7
When u r using it on the serial interface and if the encapsulation is not frame-relay it should work normally and just to add there is no dr/bdr election.
Mahmood
so, are we saying multicast/broadcast works on normal serial interfaces fro this ?
