OSPF routing troubleshooting
Hi All,
I'm facing a strange issue in OSPF router advertisement. If we advertise a specific IP in OSPF and that is causing packet drop issue for all the subnets in the switch.
Can you throw few troubleshooting steps in OSPF to identify the issue?
Thiyagu
6 Replies 6
what kind of traffic is sent from the subnet and destined to it.
Check if the bandwidth is getting chowk because of it.
Also have a look at the subnet if any overlapping is there..
Please rate the helpful posts..
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hello
Are you summarising anywhere?
Can you post some config:
Sh ip protocols
Sh run | sec router
Sh ip int brief
Sh ip ospf
Res
paul
Kind Regards
Paul
Thanks All... I would like to know command to find uptime of a OSPF route in OSPF database and when was the last OSPF re-convergence time for a specific area.
Thiyagu
Show when was SPF algh. last time executed.
show ip ospf topology-info
http://www.cisco.com/en/US/docs/ios/mtr/command/reference/mtr_02.html#wp1165403
Show SPF calculation statistics
show ip ospf statistics [detail]
http://www.cisco.com/en/US/docs/ios/iproute_ospf/command/reference/iro_osp3.html#wp1014222
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Please find the command as
sh ip ospf rib a.b.c.d
            OSPF Router with ID (x.y.v.c) (Process ID 9)
                Base Topology (MTID 0)
OSPF local RIB
Codes: * - Best, > - Installed in global RIB
*>  9.9.t..l/32, Intra, cost 2, area 0
     SPF Instance 32, age 00:00:12
     Flags: RIB, HiPrio
      via 9.9.23.3, GigabitEthernet0/0.23, flags: RIB
       LSA: 1/9.9.y.z3/9.9.x.x
The easiest way - sh ip route x.x.x.| in Last
To  ensure the ospf database is uptodate and LSA's are identical in every router - ospf uses flooding  as way to handle a changes to this database-
http://ospf.cs.st-andrews.ac.uk/index.shtml?floods&040000
res
Paul
Kind Regards
Paul
