Ospf Stub Area configuration on nexus 3k
Rowlands Price
  • Hi Support,
i have a nexus 3k and i want to configure ospf with a stub area (area 10)
i want all the connected networks be on that stub area
attached is the diagram and the nexus config
Return to my previous answer' if you redistreibte the route will be lsa5 E1/E2'
If you config vlan with ospf (not redistrubte) you can put these subnet into stub area.
MHM
6 Replies 6
MHM
Hi MHM,
if i understand, i i redistributed the connected routes (vlans) and static, it's not possible to put theses subnets to a stub area?
Exactly' that correct.
MHM
Ok, you are right, now can i have the config of stub area
i have done the lab with distributed static and connected now i need the config with stub area and i will choose one
And as you mention before' use summary to reduce number of prefix.
Good luck freind
MHM
Hi MHM, do you have an idea of configuring a stub area on nexus 3k?
i did it well on catalyst
