OSPF suboptimal path
rafael2gc
I´m having an issue with ospf related to the fact that OSPF always prefer an INTRA-area route over an INTER-area.
The point is that the INTER-area path is the optimal path couse it is 10G.
There is any way, except put all elements on area 0, to solve this issue?
Rafael
13 Replies 13
Reza Sharifi
A. According to section 11 of RFC 2328 leavingcisco.com, the order of preference for OSPF routes is:
  • intra-area routes, O
  • interarea routes, O IA
  • external routes type 1, O E1
  • external routes type 2, O E2
This rule of preference cannot be changed.
http://www.cisco.com/en/US/tech/tk365/technologies_q_and_a_item09186a0080094704.shtml#q13
Hi Reza,
in order to circumvent this order of preference which can't be changed, couldn't we use longest match traffic engineering?
Regards.
Alain.
Hi Alain,
This can possibly be provided by using MPLS/RSVP and building bidirectional tunnels.  This way, the IGP path is not followed.
Reza
Hi Reza Sharifi, thank you for your time.
I already knew this rules,  i need re-design this OSPF solution.
Imagine two rings, one is 10G  with 3 elements in area 0 and another is 1G with 60 elements in area 1.
The 3 10G elements are ABR with area 1, it has tengig interface in area 0 and 1gig interface in area 1.
The problem is when i advertise the loopback of elements in area 1.
Imagine one element that is one 1gig hop from the 10G ring, instead of goes through 1gig hop then take the 10G hop to the destination, it goes through many 1gig hops through the 1G ring to the same destination.
It happen becouse of the order preference you show us.
The point is, how make the traffic use the optimal path by the 10G ring? Put all in area 0 is not desirable.
thanks
Rafael
Rafael,
Can you provide a simple diagram showing how you are planning to design this network with 1Gig and 10Gig?
Reza
Hi Reza,
isn't there a simpler solution than MPLS/RSVP? using the longest match forwarding principle depending on topology of course.
Regards.
Alain.
Reza,
There we go.
Lets take sw-1 as an example.
The traffic from CE connected to SW-1 goes through the 1G ring to reach resources on DC.
I know why. I need a way to overcome this behavior.
Rafael,
How about putting each section around area 0 a different area?
Area 0 in the middle
lower section area 1
left side area 2
right side are 3
Reza,
I understod what you said but this is not a definitive solution.
Lets take the right side. Imagine the last switch in this section.
To go to DC it will take the path along the 1G ring, not the path through the ABR and them the 10G ring.
Got it?
Rafael
If you put each section in a different area, then in your example the last switch in the right side will take the 1Gig way up until it gets to the ABR.  From there, it will take the 10Gig path (shortest path) to DC.
Sorry Reza but a have to disagree.
Think about the loopback of this switch being advertised to the CORE-Router that is connected to DC.
The CORE-Router will always preffer the INTRA-area route over the INTER-area, becouse of this, CORE-Router will always prefer the 1Gig path over the 10Gig, unless the 1Gig ring is open.
agree?
Rafael
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
I believe what Reza proposed (one area per diagramed ring) would work as long as you weren't using summaries and DC destinations were either in area zero or different area from the rings.
"The CORE-Router will always preffer the INTRA-area route over the  INTER-area (correct), becouse of this, CORE-Router will always prefer the 1Gig  path over the 10Gig, unless the 1Gig ring is open. (correct with your diagramed topology - not so if rings are different areas, as I believe is what Reza proposed)"
Disclaimer
Posting
Another approach, you can trunk the two areas across the 10gig link.  I've used it.  Works fine.
This approach also handles the situation if you summarize a non-zero area.
This approach also supports different non-zero areas.  If, for instance, if you wanted to partition your three area 1 segments into different areas.
