OSPF totally NSSA and route redistribution
nicovpp10
I am trying ton convert a standard working  OSPF area into a totally NSSA area but I do have problem with route metric.
I do not know if it is a design limit (or a bad design from myself..)
Thanks !
Here is the network diagram :
OSPF STANDARD AREA
Using GNS3 & C3725
R1# (ABR)
interface FastEthernet0/0
 ip address 10.40.24.1 255.255.255.0
 duplex auto
 speed auto
no shut
interface FastEthernet0/1
 ip address 10.25.2.2 255.255.255.0
 duplex auto
 speed auto
no shut
router ospf 252
 router-id 0.0.252.2
 log-adjacency-changes
 auto-cost reference-bandwidth 10000
 network 10.25.2.0 0.0.0.255 area 0
 network 10.40.24.0 0.0.0.255 area 324
R8# (ABR)
 ip address 10.30.24.1 255.255.255.0
 duplex auto
 speed auto
no shut
 ip address 10.25.2.1 255.255.255.0
 duplex auto
 speed auto
no shut
router ospf 252
 router-id 0.0.252.1
 network 10.30.24.0 0.0.0.255 area 324
R2# (ASBR with redistribute static)
 ip address 10.40.24.29 255.255.255.0
 ip ospf priority 0
 duplex auto
 speed auto
no shut
 ip address 10.30.24.29 255.255.255.0
 ip ospf priority 0
 duplex auto
 speed auto
no shut
interface FastEthernet1/0
 ip address 10.10.10.1 255.255.255.0
 duplex auto
 speed auto
no shut
router ospf 10
 router-id 0.3.24.29
 redistribute static metric-type 1 subnets
ip route 71.71.71.0 255.255.255.0 10.10.10.2
R3# (ASBR with redistribute static)
 ip address 10.40.24.39 255.255.255.0
 ip ospf priority 0
 duplex auto
 speed auto
no shut
 ip address 10.30.24.39 255.255.255.0
 ip ospf priority 0
 duplex auto
 speed auto
no shut
 ip address 10.20.10.1 255.255.255.0
 duplex auto
 speed auto
no shut
router ospf 10
 router-id 0.3.24.39
ip route 72.72.72.0 255.255.255.0 10.20.10.2
From R1 & R8, routes are OK
R1#sh ip route ospf
     71.0.0.0/24 is subnetted, 1 subnets
O E1    71.71.71.0 [110/1020] via 10.40.24.29, 00:10:40, FastEthernet0/0
     10.0.0.0/24 is subnetted, 3 subnets
O       10.30.24.0 [110/2000] via 10.40.24.39, 00:10:50, FastEthernet0/0
                   [110/2000] via 10.40.24.29, 00:10:50, FastEthernet0/0
     72.0.0.0/24 is subnetted, 1 subnets
O E1    72.72.72.0 [110/1020] via 10.40.24.39, 00:10:40, FastEthernet0/0
R8#sh ip route ospf
O E1    71.71.71.0 [110/1020] via 10.30.24.29, 00:11:19, FastEthernet0/0
O       10.40.24.0 [110/2000] via 10.30.24.39, 00:11:19, FastEthernet0/0
                   [110/2000] via 10.30.24.29, 00:11:19, FastEthernet0/0
O E1    72.72.72.0 [110/1020] via 10.30.24.39, 00:11:19, FastEthernet0/0
OSPF TOTALLY NSSA AREA
Add following config :
R1 & R8#
router ospf 252
area 324 nssa no-summary
R2 & R3#
router ospf 10
area 324 nssa
From R1 & R8, routes are E1 instead of N1, duplicate / NOK / wrong metric
R8#sh ip route ospf
O E1    71.71.71.0 [110/2020] via 10.30.24.39, 00:00:31, FastEthernet0/0
                   [110/2020] via 10.30.24.29, 00:00:31, FastEthernet0/0
O       10.40.24.0 [110/2000] via 10.30.24.39, 00:00:31, FastEthernet0/0
                   [110/2000] via 10.30.24.29, 00:00:31, FastEthernet0/0
O E1    72.72.72.0 [110/2020] via 10.30.24.39, 00:00:31, FastEthernet0/0
R1#sh ip route ospf
O N1    71.71.71.0 [110/1020] via 10.40.24.29, 00:00:16, FastEthernet0/0
O       10.30.24.0 [110/2000] via 10.40.24.39, 00:00:16, FastEthernet0/0
                   [110/2000] via 10.40.24.29, 00:00:16, FastEthernet0/0
O N1    72.72.72.0 [110/1020] via 10.40.24.39, 00:00:16, FastEthernet0/0
as far as I know, the OSPFv2 implementation in IOS still follows the preference rules defined in (obsolete) RFC 1587:
When a type-5 LSA and a type-7 LSA are found to have the same type and an equal distance,
the following priorities apply (listed from highest to lowest) for breaking the tie.
a. Any type 5 LSA.
b. A type-7 LSA with the P-bit set and the forwarding address non-zero.
c. Any other type-7 LSA.
That's why R8 installs the E1 route instead of the N1.
But that doesn't mean that traffic for this destination is forwarded to the originator of that E1 route (R1), as the exit-interfaces of the E1 route demonstrate (Fa0/0 => R2/R3 NSSA).
The path (and the metric) is calculated by evaluating the path to the forwarding address of the external LSA.
As far as I see, the corresponding IP interfaces of the next hops for the static routes are not OSPF enabled, so the ASBRs have to chose the IP of another OSPF enabled interface as forwarding address (FA). You can check the FA with 'show ip ospf database [nssa-]external'. Then, a 'show ip route <forwarding-address>', will show you where the cost of the external routes come from. An interesting debug-command (for R8) is 'debug ip ospf spf external'.
Just paste the relevant output of the two show-commands if it's stil unclear; I guess it's easier to explain with a concrete example.
Rolf
16 Replies 16
Hello
When you changed to a NSSA no summary you are saying  this area should maitain and and propergate LSA types 1,2,7 and a default route
This area shoult NOT maintain INTER-AREA routes but must have the ability to connect to them.which where the default route is injected.
Also the ABR will convert LSA type 7 (n) to type 5.(e), hence why you see E routes instead of N routes.
sh ip ospf  database nssa-external | in Link State
sh ip ospf  database external | in Link State
res
Paul
Kind Regards
Paul
Hello Paul,
Thanks for your reply. I agree with you for the totally NSSA specifications.
R1 has :
- N1 routes
- Highest router ID (0.0.252.2 for R1 instead 0.0.252.1 for R8) => so responsible for translating lsa 7 (N1) in lsa 5 (E1) => sent it back to R8
What I still do not understand (all interfaces have a cost of 1000)
E1 and N1 are both External Type-1 routes, so R8 should have :
- N1 routes in its routing table (lowest metric 1020)
- E1 routes in database only (highest metric 2020)
Also, based on the previous network diagram :
- If I stop R1, routing tables on R8 are still wrong (clear ip ospf process made on all routers) :
R8#sh ip route ospf
O N1    71.71.71.0 [110/2020] via 10.30.24.39, 00:00:40, FastEthernet0/0
                   [110/2020] via 10.30.24.29, 00:00:40, FastEthernet0/0
O       10.40.24.0 [110/2000] via 10.30.24.39, 00:00:40, FastEthernet0/0
                   [110/2000] via 10.30.24.29, 00:00:40, FastEthernet0/0
O N1    72.72.72.0 [110/2020] via 10.30.24.39, 00:00:40, FastEthernet0/0
- If I make a "full mesh" topology (connect R8 on SW1 with subnet 10.40.24.0/24 & R1 on SW3 with subnet 10.30.24.0/24) routing tables are OK.
=> Looks like there are specific topology requirements for totally NSSA areas but I wasn't able to find some documentation on this
a. Any type 5 LSA.
Rolf
As far as I know, the OSPFv2 implementation in IOS still follows the
preference rules defined in (obsolete) RFC 1587.
After a quick research I found this:
In Cisco IOS Release 15.1(2)S and later releases, RFC 3101 replaces RFC 1587,
and RFC 3101 behavior is automatically enabled.
You can choose the route selection behavior by configuring a router
to run as RFC 3101 or RFC 1587 compatible.
R1#show ip ospf
 Supports NSSA (compatible with RFC 3101)
With such a release both ABRs would install N1 routes.
However, the route to the FA is still evaluated to calculate the path. This is by the way not NSSA-specific, Type-5 LSAs are processed the same way. "Exception": When the FA is set to 0.0.0.0 (rather the rule than the exception), the path to the originating ASBR is evaluated instead.
Rolf
That would explain why I was seeing N1 routes on both ABRs when I did a quick lab for this.
As always thanks for my continuing education in OSPF :-)
Jon
Good evening Jon,
believe it or not: I learned many new things about OSPF today too ;-)
Rolf
Hi Rolf,
Thanks for your reply, for sure that helps.
You are right, I have checked on R8, the FA to subnet 71.71.71.0/24 is 10.40.24.29 & 72.72.72.0/24 is 10.40.24.39
R8#sh ip ospf database external
            OSPF Router with ID (0.0.252.1) (Process ID 252)
                Type-5 AS External Link States
  Routing Bit Set on this LSA
  LS age: 1131
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 71.71.71.0 (External Network Number )
  Advertising Router: 0.0.252.2
  LS Seq Number: 80000003
  Checksum: 0x845E
  Length: 36
  Network Mask: /24
        Metric Type: 1 (Comparable directly to link state metric)
        TOS: 0
        Metric: 20
        Forward Address: 10.40.24.29
        External Route Tag: 0
  LS age: 1114
  Link State ID: 72.72.72.0 (External Network Number )
  Checksum: 0xECE8
  Length: 36
  Network Mask: /24
        TOS: 0
        Metric: 20
        Forward Address: 10.40.24.39
R8#sh ip ospf database nssa-external
                Type-7 AS External Link States (Area 324)
  LS age: 1140
  Options: (No TOS-capability, Type 7/5 translation, DC)
  Advertising Router: 0.3.24.29
  Checksum: 0x7728
  Length: 36
  Network Mask: /24
        TOS: 0
        Metric: 20
  LS age: 1123
  Advertising Router: 0.3.24.39
  Checksum: 0xA3E4
  Length: 36
  Network Mask: /24
        TOS: 0
        Metric: 20
And the route to network 10.40.24.0/24 is the following :
R8#sh ip route 10.40.24.29
Routing entry for 10.40.24.0/24
  Known via "ospf 252", distance 110, metric 2000, type intra area
  Last update from 10.30.24.39 on FastEthernet0/0, 00:19:35 ago
  Routing Descriptor Blocks:
    10.30.24.39, from 0.0.252.2, 00:19:35 ago, via FastEthernet0/0
      Route metric is 2000, traffic share count is 1
  * 10.30.24.29, from 0.0.252.2, 00:19:35 ago, via FastEthernet0/0
Debug command is really long (I can paste if you think it's useful)
If have also tried to enable OSPF on interfaces where static routes are pointing / redistributed. After that routing tables are OK. The only problem is that I do not want to enable OSPF on these interfaces (in real network it represents fortigate firewalls which redistribute static routing to a blackhole interface... something useful for NAT purpose). I will check if there is an other way.
Thanks again
Nicolas
And I suppose that the non null forwarding address for the LSA is a NSSA / totally NSSA only behaviour (as documented here https://tools.ietf.org/html/rfc3101)
That is why it is working for a standard OSPF area but not a totally NSSA area ?
Again, I wouldn't say it's not working.
It's just another way OPSF calculates the path for external prefixes - originally  in order to avoid unnecessary extra-hops in multiaccess networks, in the case of NSSAs for reasons of path-optimization when more than one NSSABR exist (because only one of them translates Type-7 to Type-5).
Rolf,
Thanks again for all these informations and great explanations.
It is indeed working (not as I expected) but the more important is that I know why it happens like that.
Nicolas,
thanks for the feedback.
Well, like mentioned before, there is nothing wrong with you routing. NSSAs generally set the forwarding-address to a non-zero value and if a [nssa] external LSA contains such a non-zero FA, the path to that IP address is evaluated. So the costs are higher as they were in your previous setup (regular area 324), but this is just because the FA of the Type-5 LSAs were set to 0.0.0.0 in this case. The path for forwarding packets to the external networks is still the same.
Regarding the route types I did some testing with a 15.2(4)S IOS:
R8#show ip route ospf
      10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
O        10.40.24.0/24 [110/110] via 10.30.24.39, 00:00:16, FastEthernet1/0
O E1     71.71.71.0 [110/130] via 10.30.24.39, 00:00:16, FastEthernet1/0
O E1     72.72.72.0 [110/130] via 10.30.24.39, 00:00:15, FastEthernet1/0
R8#show ip ospf database external
  Routing Bit Set on this LSA in topology Base with MTID 0
  LS age: 191
  Options: (No TOS-capability, DC, Upward)
  LS Seq Number: 80000001
  Checksum: 0x885C
  Length: 36
  Network Mask: /24
        MTID: 0
        Metric: 20
  LS age: 48
  Checksum: 0xF0E6
  Length: 36
  Network Mask: /24
        MTID: 0
        Metric: 20
R8#
R8#s ip route 10.40.24.39
  Known via "ospf 252", distance 110, metric 110, type intra area
  Last update from 10.30.24.39 on FastEthernet1/0, 00:01:06 ago
  * 10.30.24.39, from 0.0.252.2, 00:01:06 ago, via FastEthernet1/0
      Route metric is 110, traffic share count is 1
R8#s ip ospf | i RFC
 Supports NSSA (compatible with RFC 1587) ! Non-Default setting!
R8(config)#router ospf 252
R8(config-router)#no compatible rfc1587 ! Default for this recent IOS.
O        10.40.24.0/24 [110/110] via 10.30.24.39, 00:04:51, FastEthernet1/0
O N1     71.71.71.0 [110/130] via 10.30.24.39, 00:01:54, FastEthernet1/0
O N1     72.72.72.0 [110/130] via 10.30.24.39, 00:01:54, FastEthernet1/0
R8#show ip ospf database nssa-external
  LS age: 501
  Options: (No TOS-capability, Type 7/5 translation, DC, Upward)
  Checksum: 0x7B26
  Length: 36
  Network Mask: /24
        MTID: 0
        Metric: 20
  LS age: 320
  Checksum: 0xA7E2
  Length: 36
  Network Mask: /24
        MTID: 0
        Metric: 20
R8#show ip route 10.40.24.39
  Last update from 10.30.24.39 on FastEthernet1/0, 00:05:27 ago
  * 10.30.24.39, from 0.0.252.2, 00:05:27 ago, via FastEthernet1/0
As you can see, the route type has changed, however, the calculated paths to the external networks are the same.
Rolf
Rolf,
Thanks for theses tests and your time.
In your setup, you have the following routes :
The "problem" is that 71.71.71.0/24 next hop should be 10.30.24.29 (which make the static redistribution of this subnet) to be optimized (or maybe I missed something)
Nicolas
Don't mix up FA and next-hop. The FAs are different, but the result of the routing-table lookups for both FAs is the same in this case (as they belong to the same IP subnet and the lookup is recursive):
R8#show ip ospf database nssa-external | i Link State ID|Forward Address
R8#
R8#s ip route 10.40.24.29
  Last update from 10.30.24.39 on FastEthernet1/0, 00:02:15 ago
  * 10.30.24.39, from 0.0.252.2, 00:02:15 ago, via FastEthernet1/0
  Last update from 10.30.24.39 on FastEthernet1/0, 00:02:23 ago
  * 10.30.24.39, from 0.0.252.2, 00:02:23 ago, via FastEthernet1/0
Hello
This is what i can see -
As far as I can see the N1 routes are on the ABR of area 324 which router R1 this is also the  DR for the backbone area 0  ( between R1- R8)
So the N1 routes R1 receives is then advertiesed to R8 as a type 5 with an added cost of its physical interface.
When you stop R1 do you mean diasble all links?
res
Paul
Kind Regards
Paul
