VSS on 4500x
Robin Swan
Good Morning,
On 2 brand new "out-of-the-box" switches, I want to configure VSS for the distribution layer for redundancy.  Do I have to configure the second switch too, or will it automatically populate off of the "priority" sw 1?
Thank you in Advance.
11 Replies 11
Reza Sharifi
Initially you configure the second switch.  Once you convert to VSS and it is all working, from that point you only configure the primary switch (switch-1).
Thank you for the quick responses guys!
Can I simply do a "copy tftp ..." over to the second switch then run the VSS commands?
Also, they are both 1U 16 port switches.  Can I put the VSL config on the same ports on both switches; eg: int range "t1/15 - 16", on sw1 and sw2?
To go a little further in the question, do I absolutely have to name each switch differently in the initial configs such as sw1 and sw2?  example: hostname "engineer_4500x_sw1" or can it read "engineer_4500x"; and hostname "engineer_4500x_sw2" to read engineer_4500x".
Not sure what you are asking about copy tftp ?
Yes you can use the same ports on each switch. Once it has been converted to run VSS then the switch chassis number will be placed before the actual slot/port number to distinguish between the switches.
As far as I an aware you need different names for the switches, not sure why you would want to use the same one.
Perhaps Reza can comment.
Jon
In regards to your question:  Not sure what you are asking about copy tftp ?
What I meant was, can I copy the config off of sw1 to a tftp server, then run a copy tftp run the copy run start on sw2, then run the VSS commands?
Oh yeah! would it be a good idea to set the switch priority on the switches?
As I said before, there aren't that many line that you need to add to switch 2.
You can simply copy the config from switch-1 to notepad, make the changes you need and than pate in to switch-2.
no need for priority.  If you boot both switches at the same time, switch-1 will always be the primary.
hi Guys,
I too have a similar question. Just received a pair of 4500X 16Ten G out-of-the-box switches. I have configured verbatim the example in the link
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches
The best i can get is "active active" with console message cannot execute command in remote as it is not in SSO standby state. I want to bind these two chasis using VSS and then associate the two [physical] switches with a 3 switch stack of 3650's using MEC.In a time bind at moment any reasonable suggestions welcome. Thanks
discovered my own answer.
i revereted to base config then re applied step-by-step.
i resolved the issue by not connecting the two switches until both were fully configured and had rebooted. then connecting each 10G cable in sequence the config brought the VSL up in a happy state. thought i would share.
Not sure what you are asking.  The initial config for the second switch is a few commands. (host name, portchannel config and maybe a could of other commands). You don't need tftp or anything like that.  Remember there is no need to add any major config to the second switch because once VSS is formed it will overwrite the old config.
Yes, that would be perfect.  I always do that.
You can name them whatever you like. Once VSS is configured, it is all logically one device.
Jon Marshall
Robin
You need some minimal configuration on second switch when you setup VSS.
Once you have them up and running as a VSS pair then your L2 and L3 configuration is done only on the active switch.
See this link for the initial setup -
Jon
Robin Swan
Thank you both very much!  You are extremely helpful.
Glad to help Robin.
Good Luck.
