01-27-2014 11:36 PM - edited 03-07-2019 05:50 PM
i have 2 core routers that is connected via MPLS tunnelling.
I setup a new vlan in one of the layer 3 switch at router A,
10.200.100.0/24, there is one existing vlan at 10.200.90.0/24.
router A -> router B
under the ospf routing, there is this area 0 to exchange the LAN segments through the ospf area 1.
do I have to change the wildcard mask in order for the 2nd vlan to go theough ?
router ospf 1
log-adjacency-changes
area 0 authentication message-digest
area 1 authentication message-digest
area 1 range 10.200.0.0 255.255.128.0
area 1 range 10.205.1.0 255.255.255.192
routerA#sh ip route | i 10.200.100
S 10.200.100.0/24 [1/0] via 10.200.90.4
routerA#sh ip route | i 10.200.90
C 10.200.90.0/24 is directly connected, GigabitEthernet0/0
routerB1#sh ip route | i 10.200.100
routerB#sh ip route | i 10.200.90
O 10.200.90.0/24 [19/1001] via 10.205.5.254, 1d00h, Tunnel1090
01-28-2014 12:06 AM
Your configuration looks a bit strange. You have no network statements. Do you have OSPF enabled on the interface instead with the ip ospf interface command?
Can you post show ip ospf interface brief?
It looks like you have a static route for 10.200.100.0 and then area statement under OSPF. OSPF will not summarize route unless it is in the OSPF RIB.
To just advertise the network you should put a network statement or enable OSPF on the interface with the ip ospf area command.
Daniel Dib
CCIE #37149
Please rate helpful posts.
01-28-2014 12:09 AM
routerA#sh ip ospf interface brief
Interface PID Area IP Address/Mask Cost State Nbrs F/C
Tu1090 1 1 10.205.5.254/30 1000 P2P 1/1
Tu15 1 1 10.205.2.2/30 50 DOWN 0/0
Tu0 1 1 10.205.0.10/24 50 DOWN 0/0
Di0 1 1 10.205.2.34/30 12000 DOWN 0/0
Gi0/0 1 1 10.200.90.1/24 1 DR 0/0
GVPlazaHQ#
routerB#sh ip ospf interface brief
Gi0/0 1 0 10.199.99.11/24 1 DR 0/0
Tu1011 1 1 10.205.5.41/30 1000 P2P 1/1
Tu1090 1 1 10.205.5.253/30 1000 P2P 1/1
Tu1010 1 1 10.205.5.37/30 1000 P2P 1/1
Tu1009 1 1 10.205.5.33/30 1000 P2P 1/1
Tu1008 1 1 10.205.5.29/30 1000 P2P 1/1
Tu1007 1 1 10.205.5.25/30 1000 P2P 1/1
Tu1006 1 1 10.205.5.21/30 1000 P2P 1/1
Tu1005 1 1 10.205.5.17/30 1000 P2P 1/1
Tu1004 1 1 10.205.5.13/30 1000 P2P 1/1
Tu1003 1 1 10.205.5.9/30 1000 P2P 1/1
Tu1002 1 1 10.205.5.5/30 1000 P2P 1/1
Tu1001 1 1 10.205.5.1/30 1000 P2P 1/1
Tu0 1 1 10.205.0.1/24 25 DR 1/1
interface Tunnel1090
description Tunnel to routerB
ip address 10.205.5.254 255.255.255.252
ip mtu 1500
ip virtual-reassembly
ip tcp adjust-mss 1436
ip ospf message-digest-key 1 md5 7 070C285F4D064E5240
ip ospf priority 0
keepalive 10 3
tunnel source 172.30.90.1
tunnel destination 172.30.100.1
description Tunnel to routerA
ip address 10.205.5.253 255.255.255.252
ip mtu 1500
keepalive 10 3
tunnel source 172.30.100.1
tunnel destination 172.30.90.1
02-04-2014 08:06 PM
ospf is enable on the core router at 10.200.90.1
router ospf 1
passive-interface GigabitEthernet0/0
network 10.0.0.0 0.255.255.255 area 1
distance 19
at router 2 (10.199.99.1)
router ospf 1
redistribute static metric 500 metric-type 1 subnets route-map filterstatic
network 10.199.99.0 0.0.0.255 area 0
network 10.205.0.0 0.0.0.255 area 1
network 10.205.2.0 0.0.0.255 area 1
network 10.205.3.0 0.0.0.255 area 1
network 10.205.4.0 0.0.0.255 area 1
network 10.205.5.0 0.0.0.255 area 1
default-information originate
distance 19
how do i change the ospf to enable 10.200.100.0/24 instead of static route
02-05-2014 03:18 AM
It's not clear what you are asking.
Is the new network 10.200.100.0/24 a common network between router 1 and router 2 ie. both routers have an interface in that network.
Or does the network only connect to the one router ? If so which one.
How is this related to the static statement ?
Jon
