OSPF
cisconoobie
Level 7
Level 7
How does OSPF determine the best optimal path to another router?
Does it care about speed of the links to the given router ?
ankbhasi
Hi Friend,
OSPF looks for the bandwidth configured on the interface and if not configured then the default bandwidth for that interface.
The shortest path is calculated using the Dijkstra algorithm. The algorithm places each router at the root of a tree and calculates the shortest path to each destination based on the cumulative cost required to reach that destination.
Have a look at this link and it will clear you doubt
http://www.cisco.com/warp/customer/104/1.html#t5
Ankur
*Pls rate all helpfull post
