OTV on ASR 1001
Toi Seng Chang
Hi All,
Is there anyone experienced deploy OTV using ASR 1001 between 2 datacenters? We want to acquire HSRP localization there, but at this moment I can only see lots docs are saying how to do this on N7K, not ASR. I saw it has a FHRP filtering enabled by default when the OTV configuration is done, and also see there is a access-list created by default call otv_filter_fhrp, Im just wondering besides this IP ACL there should be MAC ACL applied also, anyone have sample configuration on this? Many thanks.
Bilal Nawaz
Hello you are correct, there is a Layer 2 mac access list to be applied. I did this a while ago.
The otv filter-hsrp only blocks pdu's from traversing the overlay, but you still need to stop on the ethernet flow points (EFP's) for HSRP mac address being learned.
https://supportforums.cisco.com/thread/2173395
!HSRP L2ACL
mac access-list extended FILTER_HSRP
deny 0000.0c07.ac00 0000.0000.00ff any
permit any any
interface overlay 1
otv filter-fhrp
Service Instance 100
Ethernet encapsulation dot1q 100
mac access-group FILTER_HSRP out
bridge-domain 100
More info here for HSRP, GLBP and VRRP:
http://www.cisco.com/en/US/docs/ios-xml/ios/wan/command/wan-m1.html#wp3953249580
Hope this helps.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hi Bilal,
Thanks for your prompt. It helps me a lot.
Besides, we now have problems with OTV AED not capable, I have checked that the site bridge-domain is permitted on the internal interface of ASR, and I have put Join interface & internal interface & overlay interface into a vrf besides the default router, and the routing (otv extended vlan gateway & core uplink interface) into default router, but the OTV adjacency disappeared then. Here is the output, any comments?
SPRTORT01#show otv site
Site Adjacency Information (Site Bridge-Domain: 3010)
Overlay1 Site-Local Adjacencies (Count: 1)
  Hostname       System ID      Last Change Ordinal    AED Enabled Status
* SPRTORT01      B0FA.EB8E.7C80             -          Not AED capable
SPRTORT01#show otv detail
Overlay Interface Overlay1
VPN name                 : SAFP_OTV_1
VPN ID                   : 1
State                    : UP
AED Capable              : No, overlay DIS not elected
IPv4 control group       : 239.1.1.1
Mcast data group range(s): 232.1.1.0/28
Join interface(s)        : GigabitEthernet0/0/0
Join IPv4 address        : 172.30.0.101
Tunnel interface(s)      : Tunnel0
Encapsulation format     : GRE/IPv4
Site Bridge-Domain       : 3010
Capability               : Multicast-reachable
Is Adjacency Server      : No
Adj Server Configured    : No
Prim/Sec Adj Svr(s)      : None
OTV instance(s)          : 0
FHRP Filtering Enabled   : Yes
ARP Suppression Enabled  : No
ARP Cache Timeout        : 600 seconds
Hello, Just to check over config, are you able to post it here?
Also please check that your OTV vlan that is used for election etc... Is not on your overlay interface, should only be on your inside interface.
Hope this helps
jkilleda
Level 3
Level 3
Hello Toi Seng,
OTV on ASR 1001
You can refer to the example given in the link provided.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_otv/configuration/xe-3s/wan-otv-xe-3s-book/wan-otv-adj-server.pdf
