Out of the Box Meraki Configuration
Geeman365
I am interested in know what the base out of box configuration is for a Meraki MX84 Router is.  I know that DHCP is turned on for the device but I would like to know what else is turned on or included up.  Is portfast enabled?  STP or RSTP?  I am a little confused not using the CLI to investigate the Router and I wanted know, upon power up and besides the DHCP Option being turned on, what other features/services are turned on/enabled with Meraki MX84.
RKarimov
Hello.
I think, PVST+ (STP's) is enabled by default. Not sure about portfast. But to enable it for all interfacesspanning-tree portfast default.
Philip D'Ath
The MX family of products do not support spanning tree of any kind.  There is also no concept of portfast (why would there be with no spanning tree).
The WAN interfaces default to being a DHCP client.  They use that to connect to the Internet and then download their config.  Prior to getting a config the LAN ports have a DHCP server operating so you can plug in a notebook and use the local status page to change the WAN port configuration (such as static IP, PPPoE, VLAN tag, etc) or check for errors.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Meraki_Device_Local_Status_Page
