OutDiscards errors on 6509 swports with disconnecting Citrix session
We are seeing counter errors on switchports.
sho int gig1/4 counter errors
Port        Align-Err    FCS-Err   Xmit-Err    Rcv-Err UnderSize OutDiscards
Gi1/4               0          0          0          0         0    18556248
Port      Single-Col Multi-Col  Late-Col Excess-Col Carri-Sen     Runts    Giants
Gi1/4              0         0         0          0         0         0         0
Port       SQETest-Err Deferred-Tx IntMacTx-Err IntMacRx-Err Symbol-Err
Gi1/26              0          0          0          0         0     5752272
Gi1/26             0         0         0          0         0         0         0
Gi1/26               0           0            0            0          0
Here is the configuration on the ports. Can the speed and duplex causing the outdiscards error?
interface GigabitEthernet1/4
switchport
switchport trunk native vlan 201
switchport mode trunk
switchport voice vlan 202
no ip address
speed 100
duplex full
mls qos trust dscp
spanning-tree portfast
patrick.preuss
Can be Too much Traffic . If you have more them 100 mbit xmit Traffic The switch has to drop packets this will result in diaconnected sessions.
Thanks Marc.
The hosts connected to the interfaces are just thin clients. is this a possible issue of broadcast storms?.
