Upgrade path for Cisco Nexus 5010s running 4.1(3)N2(1)
Rick Pancratz
I would like to perform nondisruptive upgrades on two Cisco Nexus 5010s that currently run NX-OS version 4.1(3)N2(1) to
Release 5.1(3)N2(1a).  Is this possible?  Or, do I need to upgrade to Release 5.0(2)N1(1) first?
Thank you in advance for all assistance/insights.
-Rick
Leo Laohoo
You should be able to do an ISSU to NS-OS version 5.0(3)N2(2b) before continuing.
Cisco Nexus 5000 Series and Cisco Nexus 2000 Series Release Notes, Cisco NX-OS Release 5.1(3)N2(1a) and Release 5.1(3)N2(1)
Supported Upgrade and Downgrade Paths
Leo Laohoo
Good afternoon Leo,
I was mistaken regarding the starting release for the Nexus 5010Ps.  They are both currently running 4.2(1)N1(1).  When I run through the pre-upgrade verification process I am informed that I must peform a disruptive upgrade to 5.0(3)N2(2b) due to STP configuration issues with upstream Cisco 4900s.  That is OK.  I plan to perform the disruptive upgrade to 5.0(3)N2(2b) on both switches and then perform another disruptive upgrade on each to reach release 5.1(3)N2(1a) during a maintenance window this weekend.   To the best of your knowledge, are there any further caveats that I need to plan for during this upgrade process?
Thanks again for your insights.
Rick
Hi Rick,
The method you mentioned will work fine. When I work with customers on an upgrade, I usually do them one at a time when they are disruptive. That way if you are using vPC traffic can continue on the active switch while the other reloads for the upgrade.
Anthony
