Output Drops in Cisco 2960
Sgj
I found Output Drops in some Interfaces in Cisco 2960 series and want to solve this.
But when trying to type the command 'qos queue-softmax-multiplier 1200' , it doesn't work.
I already try this command in other series, it works.
Does anybody know the correct command of 'qos queue-softmax-multiplier 1200' in the 2960 series?
Thanks in advanced
29 Replies 29
balaji.bandi
when you mention other series what is the model and IOS, what is the IOS version of 2960 here ?
BB
In 9200 and 3650 series
an alternative to the softmax settings (since they are not available, and if they were, do not always eliminate output drops) would be to do some interface buffer tuning. For that, post the output of (provided you have 'mls qos' enabled globally}:
2960(config)#mls qos
2960#show mls qos maps dscp-output-q
2960#show mls qos queue-set
You could also try and disable 'mls qos' altogether, if you have it enabled, that sometimes reduces or eliminates the output drops.
And last but not least, you could try some generic queue tuning:
mls qos
mls qos queue-set output 1 threshold 1 3200 3200 25 3200
mls qos queue-set output 1 threshold 2 3200 3200 25 3200
mls qos queue-set output 1 threshold 3 3200 3200 25 3200
mls qos queue-set output 1 threshold 4 3200 3200 25 3200
Thanks for the reply,
Here's the information :
sorry, my bad, I also need the output of:
show mls qos interface gix/x statistics
of the interface where the output drops are occuring.
There are 2 interfaces where the output drops, Fa0/14 & Fa0/24.
There's already a command with 'mls qos queue-set output 1 threshold . . .',
Do I have to replace it with,
for options other than command 'qos queue-softmax-multiplier 1200'?
Thanks in advanced
post the output of:
show mls qos interface FastEthernet0/14 statistics
show mls qos interface FastEthernet0/24 statistics
The values:
are generic, you might try them and monitor if the output drops decrease.
Here's the output from :
- Fa0/14
- Fa0/24
ok, my calculation has come up with the below. Configure this globally:
AS02-3(config)#mls qos queue-set output 2 threshold 3 3100 3100 100 3200
and this under your interfaces:
queue-set 2
queue-set 2
Okay, I've added the configuration as you said.
And I've also added a configuration like,
Thank you for your help.
I'll update again here after a few days of monitoring.
keep in mind that, if you apply the below:
it affects all ports on the entire switch (queue set 1). If you use what I proposed:
queue-set 2
queue-set 2
only the two ports are affected.
Okay, I already set the 'mls qos queue-set output 1 threshold . . . . .' to default again.
Let see after for a few days.
Thank you for your information
Curious to know the results. Keep us updated...
There's still a Drop packet,
AS02-3#sh int fa0/14
FastEthernet0/14 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is dc7b.94df.440e (bia dc7b.94df.440e)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 4/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:40, output 00:00:01, output hang never
Last clearing of "show interface" counters 3d15h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 25981
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 349000 bits/sec, 344 packets/sec
5 minute output rate 1787000 bits/sec, 404 packets/sec
1734648 packets input, 249446073 bytes, 0 no buffer
Received 399255 broadcasts (296169 multicasts)
0 watchdog, 296169 multicast, 0 pause input
1787816 packets output, 553201068 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
AS02-3#sh int fa0/24
FastEthernet0/24 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is dc7b.94df.4418 (bia dc7b.94df.4418)
Last input 00:00:32, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4482
5 minute input rate 27000 bits/sec, 8 packets/sec
5 minute output rate 58000 bits/sec, 15 packets/sec
617103 packets input, 84796619 bytes, 0 no buffer
Received 93908 broadcasts (24643 multicasts)
0 watchdog, 24643 multicast, 0 pause input
1821075 packets output, 382143080 bytes, 0 underruns
