Output Drops on Priority Queue 1 on Cisco 9300 Switch
anil.kumar2508
Hello Community members,
I am struggling with Output drops on PQ1 (QoS) on my several cisco 9300 series switches. Ports(Te1/1/1 & Te1/1/2) configured as port-channel. Packets are only dropping on interface Te1/1/1. qos queue-softmax-multiplier 1200 already applied. Please help in resolving this issue.
Please find my config
Switch Ports Model SW Version SW Image Mode
* 1 62 C9300-48U 16.6.8 CAT9K_IOSXE INSTALL
TenGigabitEthernet1/1/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is xxxxx
Description: "Link to "
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:02, output hang never
Last clearing of "show interface" counters 2d05h
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 2632463712
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 134000 bits/sec, 160 packets/sec
5 minute output rate 1909000 bits/sec, 231 packets/sec
42106757 packets input, 17561926962 bytes, 0 no buffer
Received 3887697 broadcasts (3665080 multicasts)
0 watchdog, 3665080 multicast, 0 pause input
49175423 packets output, 48495711222 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
My Output policy
Policy Map EGRESS_policy
Class Voice_EGRESS
priority level 1 10 (%)
Class VIDEO_EGRESS
priority level 2 20 (%)
Class SGL_EGRESS
bandwidth remaining 5 (%)
queue-buffers ratio 10
Class BUSINESS_EGRESS
bandwidth remaining 30 (%)
queue-buffers ratio 30
Class HTD_EGRESS
bandwidth remaining 10 (%)
Class class-default
bandwidth remaining 25 (%)
queue-buffers ratio 25
queue-limit dscp cs1 percent 80
Switch#$fed switch active qos queue config interface te1/1/1
DATA Port:52 GPN:1344 AFD:Enabled QoSMap:0 HW Queues: 416 - 423
DrainFast:Disabled PortSoftStart:2 - 10800
DTS Hardmax Softmax PortSMin GlblSMin PortStEnd
0 1 6 65 6 65 0 0 0 0 6 14400
1 1 7 60 7 2880 2 180 0 0 6 14400
2 1 4 0 11 2400 2 150 1 75 6 14400
3 1 4 0 12 7200 2 450 1 225 6 14400
4 1 4 0 11 2400 2 150 1 75 6 14400
5 1 4 0 13 6000 2 375 1 187 6 14400
6 1 4 0 5 0 0 0 0 0 6 14400
7 1 4 0 5 0 0 0 0 0 6 14400
Switch#$fed switch active qos queue stats interface te1/1/1
DATA Port:52 Enqueue Counters
Queue Buffers Enqueue-TH0 Enqueue-TH1 Enqueue-TH2
0 0 0 48172083 21562065282
1 0 0 0 1404210692
2 0 0 0 665075768
3 0 0 0 28934704
4 0 0 0 5574111
5 0 20081050 0 56583672096
6 0 0 0 0
7 0 0 0 0
DATA Port:52 Drop Counters
Queue Drop-TH0 Drop-TH1 Drop-TH2 SBufDrop QebDrop
0 0 67878 34555331980 0 0
1 0 0 0 0 0
2 0 0 0 0 0
3 0 0 0 0 0
4 0 0 0 0 0
5 0 0 0 0 0
6 0 0 0 0 0
7 0 0 0 0 0
See Queue drops in attached pic.
Thanks a lot.
11 Replies 11
looks like the drops occur in the first class (Voice_EGRESS) in your policy. Change the queue buffer ratios as below:
Class Voice_EGRESS
queue-buffers ratio 35
Class VIDEO_EGRESS
Class SGL_EGRESS
Class HTD_EGRESS
Class class-default
Hi George,
Thanks for the reply but unfortunately drops are still increasing.
Switch#sh int te1/1/1
Hardware is Ten Gigabit Ethernet, address is xxxxxxxx
Description: "Link "
Keepalive not set
Last clearing of "show interface" counters 00:05:48
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 18751648
5 minute input rate 129000 bits/sec, 157 packets/sec
5 minute output rate 1940000 bits/sec, 238 packets/sec
54419 packets input, 6098718 bytes, 0 no buffer
Received 6607 broadcasts (6295 multicasts)
0 watchdog, 6295 multicast, 0 pause input
84137 packets output, 86081217 bytes, 0 underruns
Class Voice
Class VIDEO_EGRESS
Class SGL_EGRESS
Class HTD_EGRESS
Class class-default
Can we remove percent from priority Queue 1? what would be the effect? Also can we somehow increase the burst size?
the problem is possible with the other side. What do you have connected on the other side of the port channel ? Check the corresponding interface for input errors or input queue drops...
Other side it is connected to cisco WS-C6509-E. No errors or output drops on port..
interface GigabitEthernet1/6/4
description  Critical
switchport
switchport trunk allowed vlan 1,72,168,253,313,431,432,610,741-744,835
switchport mode trunk
channel-group 103 mode active
service-policy type lan-queuing input QUEUING-2Q4T-IN
service-policy type lan-queuing output QUEUING-1P3Q4T-OUT
end
GigabitEthernet1/6/4 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is xx.xx.xx.
Description: Critical
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:25:29
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
5 minute input rate 3060000 bits/sec, 459 packets/sec
5 minute output rate 466000 bits/sec, 190 packets/sec
664585 packets input, 557439144 bytes, 0 no buffer
Received 839 broadcasts (733 multicasts)
0 watchdog, 0 multicast, 0 pause input
716725 packets output, 350182572 bytes, 0 underruns
on interface GigabitEthernet1/6/4, try and turn flow control on:
flowcontrol receive on
Still No change after the flowcontrol receive on
Joseph W. Doherty
I believe, what I've highlighted, above, is the cause of your drops.
From my reading, with "qos queue-softmax-multiplier 1200" already applied, I would expect a larger value.  Maybe a bug?
Anyway what can you try, beyond trying moving to a later IOS version?
Your 9300-48U should be a dual ASIC model, and buffer resources are per ASIC.  So, using a different port, if possible, might relieve the problem (also perhaps why you don't see this issue on the other Etherchannel link - unless that's because of hashing choice).
You also might try a variant of what Georg already suggested, using the "queue-buffer ratio" command, but just on Voice class (alone).
You might also try increasing the bandwidth allocation to this class (or removing it, which I think just disables the policer).  BTW, the priority command also offers a burst parameter, but I don't think you're hitting the implicit police limit.  (So why change bandwidth allocation?  It might increase buffer allocations.)
You might also try the class queue-limit command, on this class.
Further, unless you know you have a lot of Voice traffic, as a level 1 PQ, seeing queuing for this traffic would seem unusual, especially as microbursts (and as your 5 minute load average is low).  You might confirm some other traffic isn't incorrectly/"illegally" using this class.
Hi Joseph,
i did couple of tests on another switch facing same issue.
1) Removed output policy from the port----> No output drops at all.
2) I swapped the P1 Queue with P2 Queue i.e. my voice traffic now hitting P2 Queue----> But still i saw drops on P1 Queue only. No drops on P2 Queue . So i think we can rule out issue with my voice traffic.
In this switch 5 security cameras are connected and having very less traffic.
Even if i increase PQ1 percent to 30% still packet drops are there.   priority level 1 percent 30
So why only PQ1 is dropping traffic.
Why need to add buffers-ratio even if traffic volume is low. Same Traffic is not dropping on PQ2 and no queue-buffers allocated to this queue.
actually, one of Joseph's suggestions was what I was thinking of next. No queue buffers ratios on anything but the voice class:
Class Voice_EGRESS
queue-buffers ratio 75
Class VIDEO_EGRESS
Class SGL_EGRESS
Class HTD_EGRESS
Class class-default
Yea, what I would like to know/see, is with such a change, whether Q0's Softmax value changes.
"So why only PQ1 is dropping traffic."
Possibly for the same reason I've already noted, i.e. Q0's Softmax value is too small.  (I'm still wondering if it's a bug.)
When you removed the policy-map you also changed over to the default queuing policy, which uses different buffer values.
Other possible solutions, don't configure two level PQ.  Or just use the level 2 PQ for all your real-time traffic.
