output drops with interface utilization = 20% !!! in Sw 2960-S
mohamed louhab
hi ,
i noticed the "output drops" increasing in  interface gi 1/0/1 in my switch 2960-S although the utilization of my interface is between 20% and 50 %
SW__A#sh interfaces gigabitEthernet 1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 93/255, rxload 3/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:10:00
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 78484
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 14786000 bits/sec, 22426 packets/sec
  30 second output rate 365630000 bits/sec, 42896 packets/sec
     6584758 packets input, 575696417 bytes, 0 no buffer
SW__A#sh controllers gigabitEthernet 1/0/1 utilization
Receive Bandwidth Percentage Utilization   : 3
Transmit Bandwidth Percentage Utilization  : 50
SW_A#sh interfaces gigabitEthernet 1/0/1 | include Total output drops
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 585722
SW_A#sh controllers gigabitEthernet 1/0/1 utilization
Receive Bandwidth Percentage Utilization   : 1
Transmit Bandwidth Percentage Utilization  : 24
The IOS version is :
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24TD-L   12.2(55)SE5           C2960S-UNIVERSALK9-M
what is the cause of this issue ??
thank you
20 Replies 20
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Typically transient congestion (or microbursts).  Typically not "visible" across even a 30 second load average.  Worst case, transient drops will slow traffic such that it brings your effective bandwidth utilization down.  I.e. a high drop rate will very much slow rate adaptive flows.
If this is the cause, what can you do?  Possible solutions include: providing more bandwidth, providing more buffering resources, better drop management, TCP RWIN tuning.
Hi Joeseph ,
how i can providing more buffer ressources, or drop management ?
paolo bevilacqua
Is there configured any QoS/MLS on the switch?
Hi Paolo ,
no , the QOS is disable in the Switch. really  this issue drive me crazy !!!
thanks
Is no QoS or custom queuing is configured, then Joseph explaination is correct and drops are due to micro-bursts.
Hi ,
can you explain more about micro-bursts and how i can solve this issue.
thank you
That has been correctly explained by Joseph above already, or you can use the search function for more reading.
Hi ,
thank all for your help .
how i can increase the buffer in the interfaces and or drop management ?
if i enable the QOS perhaps resolve this problem ?
how about a bug in IOS ??
thank you
Add another interface for etherchannel.
Disclaimer
Posting
mohamed louhab wrote:
Hi Paolo ,
thanks
From one of your later postings, it appears QoS is enabled, otherwise would expect to see different WTD drops for different queues.
So you're sure "mls qos" isn't in your config?
Leo Laohoo
The command you are using, "sh controller util", takes an on-the-spot snapshot of the utilization of the specific link.  In your case 50%.
Basically, this means that the switch is sending 50% of the link's capabilities (about 500 Mbps) to whatever is downstream.  However, the downstream device is possibly sending "Pause" frames back.  The backed-up packets get put into a buffer or a bucket until it gets full and overflows, hence, you are seeing output drops.
Configure the link to 100 Mbps, command:  speed auto 10 100, and observe if output drops occur.
Can you also post the output to the command "sh controller eth Gi 1/0/1", please?
Hi ,
thank you Paolo ,
@leolaohoo , but i have drops in the interfaces although the utilization is 20% !!
  we suffer a problem of copy betwen my two sites
that's  why after my trubelshhoting I suspect this issue causing this problem.
i don't know if it or not interesting i put this :
SW_A#show platform port-asic stats drop gigabitEthernet 1/0/1
  Interface Gi1/0/1 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 1314629
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 10
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 250824
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
for the result of "sh controller eth Gi1/0/1" i will send to you tomorrow
thank you
I have, in our network, seen your case of output drops.  The fastest way to eliminate WHERE the problem is is to drop the speed from 1 Gbps to 100 Mbps.
Once we've proven to the people who owns and/or manage the servers that output drops from the switch to the server has decrease do the server people start talking seriously (instead of saying, "It's a network fault").
Even if the other switch is sending pause frames, the 2960S is ignoring them, as the show interface is telling us:
