Need clarification on upgrading and licensing
Max-o_o-Power
Hello All,
I am a confused about the process of upgrading and licensing afterwards.
For example, I currently have a 3560G switch running c3560-ipservicesk9-mz.122-58.SE2
I have a spare 3560 V2 switch I want to configure and have ready in case of a failure. This spare switch is running c3560-ipbasek9-mz.122-55.SE5
My plan was to pull the IOS image from the current switch and upload it to the spare that way I have an "idnetical" switch. From what I have read, there are some feature differences between "ipbase" and "ipservices". However, when I run the show license command on the production switch, I get an unrecongnized command error. So that throws into my confusion as if its running an ipservices image, shouldnt it have a license file?
Any info to clear this up is greatly appreciated.
Thanks.
paolo bevilacqua
These switches do not have licensing files and all features are dictated by the image in use.
Reza Sharifi
The older switches are not license based.  They are feature set based. Now, if the license command is supported on your 3560 V2 switch, then you can purchase additional license to upgrade it from IP base to IP services.
paolo bevilacqua
Thank you and Reza for taking the time to answer my question.
How can I identify which devices will use the new license techniques in the future?
Most newer switches are license based these days.  For example: 3750E and 3750X series are both license based.  I think, so is the new 3850.
