output drops with interface utilization = 20% !!! in Sw 2960-S
mohamed louhab
hi ,
i noticed the "output drops" increasing in  interface gi 1/0/1 in my switch 2960-S although the utilization of my interface is between 20% and 50 %
SW__A#sh interfaces gigabitEthernet 1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 93/255, rxload 3/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:10:00
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 78484
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 14786000 bits/sec, 22426 packets/sec
  30 second output rate 365630000 bits/sec, 42896 packets/sec
     6584758 packets input, 575696417 bytes, 0 no buffer
SW__A#sh controllers gigabitEthernet 1/0/1 utilization
Receive Bandwidth Percentage Utilization   : 3
Transmit Bandwidth Percentage Utilization  : 50
SW_A#sh interfaces gigabitEthernet 1/0/1 | include Total output drops
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 585722
SW_A#sh controllers gigabitEthernet 1/0/1 utilization
Receive Bandwidth Percentage Utilization   : 1
Transmit Bandwidth Percentage Utilization  : 24
The IOS version is :
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24TD-L   12.2(55)SE5           C2960S-UNIVERSALK9-M
what is the cause of this issue ??
thank you
20 Replies 20
Even if the other switch is sending pause frames, the 2960S is ignoring them,
Good point, Paolo.
Ok , thank you for all this explanation
so it 's possible to enable flow-control in the switch 2960s ?
thank you ,
hi ,
i have found it
interface Gi 1/0/1
flowcontrol  receive on
flowcontrol  send on
i will test that and i will send to you the result
thank you
Hi ,
when i activate "flowcontrol " on the interface ( by the command flowcontrol receive on) i noticed that the interfaces of the router ( ASR-1001) conneceted to this Switch  Become "shut down " !!!!
I did not understand why??? !!
It doesn't really matter, as flow control does not help at in case of output drops.
mohamed louhab
Hi ,
Yes the qos is disabled in the switch.
Sent from Cisco Technical Support Android App
