packet capture Nexus 56128
dcarr3311
I'm troubleshooting a problem with a host connected to my Nexus 56128. I would like to do a packet capture of the data going to that host. Is there an easy way to grap a .pcap file of this data from the switch?
thanks
Dan
balaji.bandi
Hi Balaji!
it appears that you can only capture control plane data with that tool. What I want to do is capture packets on the data plane from host to host.
Any thoughts on that?
Dan
Hey Dan,
You have 2 ways to accomplish this, the first is a classic monitor session where you mirror the traffic from one port(so the one where you host is connected) to a second port where you might have a sniffer attached(e.g a PC with wireshark running, or a linux box with tcpdump).
The second option is to use ELAM, this will not give you the full picture on the packets passing though as it will capture only a specific subset of traffic previously defined by a trigger with a filter.
You can find more details on ELAM here:
https://clnv.s3.amazonaws.com/2015/usa/pdf/BRKDCT-3100.pdf
and on SPAN/monitor session here:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/system_management/7x/b_5600_System_Mgmt_Config_7x/b_6k_System_Mgmt_Config_7x_chapter_01110.html
HTH,
ADP
