Packet Capture on 2960X switch interface
aravikumar
I have configured the following commands to capture packet on switch trunk interface.
monitor capture buffer BUFFER NAME
monitor capture point ip cef POINT gigabitEthernet INTERFACE-NUMBER both
monitor capture point associate POINT BUFFER
monitor capture point start POINT
When I try to export the captured packets, there were no packets in the exported pcap file.
Am I missing something here or is there a defect?
Switch model and IOS version:
Switch Ports            Model                       SW Version       SW Image
* 1        28        WS-C2960X-24PD-L    15.2(4)E6      C2960X-UNIVERSALK9-M
Please help.
Aravind.
5 Replies 5
Reza Sharifi
Not all SPAN features are supported on the 2960x series switches. What is your license level? "sh ver" should show you that.
Hi Reza,
The following is the show version of the switch
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 02:53 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(4r)E3, RELEASE SOFTWARE (fc4)
WS-C2960X-24PD-L-01 uptime is 2 weeks, 2 days, 6 hours, 45 minutes
System restarted at 05:48:27 EST Mon Jun 17 2019
System image file is "flash:/c2960x-universalk9-mz.152-4.E6.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24PD-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FOC1806S4WC
Last reset from reload command
2 Virtual Ethernet interfaces
1 FastEthernet interface
26 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B0:00:B4:2D:D7:00
Motherboard assembly number : 73-14189-04
Power supply part number : 341-0528-01
Motherboard serial number : FOC18061WUE
Power supply serial number : LIT175108W4
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C2960X-24PD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC18052ELH
System serial number : FOC1806S4WC
Top Assembly Part Number : 800-38003-01
Top Assembly Revision Number : C0
Version ID : V01
CLEI Code Number : CMMLL00ARA
Daughterboard revision number : A0
Hardware Board Revision Number : 0x05
Configuration register is 0xF
Aravind.
c2960x-universalk9-mz.152-4.E6.bin  - you have lanbase-lan lite image.
here is the restriction look the release notes :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15_2_6_e/configuration_guide/b_1526e_consolidated_2960x_cg/b_1526e_consolidated_2960x_cg_chapter_01011011.html
BB
sorry, but SPAN , RSPAN is not same as Packet capture, right?
tyoung008
TAC told me EPC is not supported on the 2960X and other switches.  Even though the 2960X does not appear on the list of products on this bug -> https://bst.cloudapps.cisco.com/bugsearch/bug/CSCui33787, it appears to also apply to the 2960X.  On a side note, using the options "process-switch" "from-us" seems to be able to capture packets from the switch.
