11-10-2020 06:30 AM
Hi Everyone..
Have a good day..
I am testing XRV 6.1.3 with the OSPF routing protocol as below in the topology. R1-R4 connection is considered. When I do "show IP route" and "show cef 4.4.4.4/32", it shows both routes but when I trace to 4.4.4.4, it only goes from one route. Results can be seen in the second pic. May I know how can I solve it? Thank you.
Topology
Output of Show commands
11-10-2020 06:45 AM
cef is per destination load balance,
hence you trace same destination you will get same result,
try ip cef distribution and see result.
11-10-2020 11:51 PM
Thanks for your reply. I am really appreciated your help.
May I know the command to see the result for "IP cef distribution" ?
As I am trying to type that command, there is no command like that in IOS XRV.
11-11-2020 03:16 AM
https://www.cisco.com/c/en/us/td/docs/ios/12_4t/ip_switch/configuration/guide/tceflbs.html#wp1046601
check this doc. how to change from per-destination to per-packet.
