Reset a 2960X correctly
InfectedGTi180
I'm trying to reset 2960X, but when the process is complete, my switch has already some old configuration line like the switch number.
I follow the method with Mode button (http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/hardware/quick/guide/b_gsg_2960xr.html#task_DF388611FF3C43C990C7F291A8D0D8BC), the write erase method (http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html#reset_switch) and the method with rommon (https://fatmin.com/2012/12/02/how-to-reset-cisco-catalyst-2960-back-to-factory-defaults/comment-page-1/).
But when it's start again, I see "switch 2 provision ws-c2960x-48ts-l"
How can I reset my switch correctly ?
Thank you
8 Replies 8
Leo Laohoo
conf t
switch 2 renumber 1
end
reload
Ok I know this command, but how can I be sure that there is no other old parameters ?
Check your stack to identify whether or not you have a switch already numbered in the stack and if so renumber switches as required.
StevensR0dney
Reset Steps
Boot to OS
Decline initial config
enable mode
show start
show ver
show flash show env all
show POS
Then use the dir flash command;
dir flash:
Shows files in flash mem
delete flash: command will erase files in flash memory
syntax:
delete flash:config-txt , confirm will delete the config.txt file
Repeat for all files
Reboot
OS will boot from NVRAM
Sorted
I have same problem on 3750G.
I reloaded in ROMMON mode. The command SET show a lot of parameters and SWITCH_NUMBER=2
unset SWITCH_NUMBER
boot
when the boot finish, my switch is number 1 again, but I think switch 2 renumber 1 is the same.
StevensR0dney
Can you supply screenshots? Anything that illustrates the problem would be welcome. I am trying to see if the problem is syntax or is the problem located in flash memory.
K@yT
Here are easy steps:
REMOVE POWER CABLE then PLUG it back again. PRESS & HOLD MODE BOTTON for 8 mins.......
You will see something like this...
CPU rev: B
Image passed digital signature verification
Board rev: 24
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:5f:86:38:4a:80
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
boot
switch: flash
Initializing Flash...
switch: del flash:config.text
Are you sure you want to delete "flash:config.text" (y/n)?y
File "flash:config.text" deleted
switch: del flash:vlan.dat
Are you sure you want to delete "flash:vlan.dat" (y/n)?y
File "flash:vlan.dat" deleted
switch: boot
Loading "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin"...Verifying image flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin...............................................................................................................................................................................................................................................................PLEASE DO RATE USEFUL info
My Cisco Catalyst 2960-x series switch is doing continous boot and has the following text in the management port configuration when i type "set" command in rommon mode:
switch:
switch: set
!Y=Hgÿ:á:麺%‡b*‚¬ÆV¾.ÂMüµ¸œBÆÎ¦*å5ŠÄ¸Nc‘ÎúCöÔ‚L“$gÒ0gÊ“¶þ�ˆõÌŒŽU¿fq&5>�_k@Úä2 ±ÐO䧦[ t,‡ž„„“’b åv‧f¨oáÒ›ëÆMØ‹-¦ÍMüÂG�yá�šôò)¼àŒÈì’ˆ\/uÈ»ú´ùôõ÷›“95v„éXGf
(=™°ÓÙ+†éa¯/e,®’~!â…hE´ÀYm�edðy/Žè5>hu­ýQÄ80¸.ÖÃ@˜Åé@ˆv_Æûè¾G²�ŸH„´~ÿߎwJ6Ñ@ƒpÊ<‡s
5W6=‹'ôxa‰i°i,mΡ2fÞG’°Óˆ„2ñ‡”Ä.ªgMá®%ßÝE¯�£>IÂÔõpFé…C:c¿_2åáŠn9Æá³1c�Ø+ˈn“¸• v,)™ï”µ“„Ñ·^Ýš`
8=˜nøˆá<oÒ·ú¼â/7›ïËElïRiþ�×P1?Þ/ÿÄãFÖ0‹VÊÛƒ¸_
9=±œ)†² ÞMÍôLX|ÿ¥†cñ¿Nžö|¾Çuõm©
?=ÌVÿE·¨„ÕLh)±Áû6'Aóõá!BWÕãü»¶Uü_eN»Ôï´·žŽYee¿„HŽ ¦oS´’ÍôÐEjÌ4“;‘š2(µ¸…š…æh{ϯë6kœ;•²{
@=”Ê`õ·}&¹_+�É~}îgó�ô—çAHŠÍ©Mìh€1æ³8+å{ˆ:�¯g`_ŽÅù½uBC#pb¶ÓNžã•PÕcXS^lE‹Iß;CÞ…âÚn[Â×EH†¹>%$
BAUD=9600
BOARD_CONFIG_REV=4
BOOT=c2960x-universalk9-mz.150-2a.EX5.bin
CLEI_CODE_NUMBER=CMMLR00ARD
DAUGHTERBOARD_ASSEMBLY_NUM=73-14200-03
DAUGHTERBOARD_REVISION_NUM=A0
DAUGHTERBOARD_SERIAL_NUM=FOC20130GDU
DEFAULT_GATEWAY=192.168.59.1
DEFAULT_ROUTER=192.168.59.1
DUAL_CORE_ENABLE=0
IMAGE_UPGRADE=no
IP_ADDR=192.168.59.36/255.255.255.0
IP_ADDRESS=192.168.59.36
IP_SUBNET_MASK=255.255.255.0
-- MORE --
LANGUAGE=ENG
MAC_ADDR=00:6C:BC:81:E0:80
MODEL_NUM=WS-C2960X-24PS-L
MODEL_REVISION_NUM=L0
MOTHERBOARD_ASSEMBLY_NUM=73-16694-04
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FOC20140KNS
Op=ßo±ÓI/g¨½S,ÃQ—ÐTÊmm8±‘¾±¸å*c_«4´L)UÙÇ�¹õYJgó¼Zii»Þ®'‚Ï÷ª2{£Ùxq¯S¤¡�˜*¤*C†K›†XLn ÌLF¿iÄhhn«'+wŠþ½tl„×)H¡··$’[Ü7‘´o¦¤ÃXd],»TÛrû^$6HªŸ0Ù:Lt
POWER_SUPPLY_PART_NUM=341-0528-02
POWER_SUPPLY_SERIAL_NUM=LIT20021B6J
SDM_TEMPLATE_ID=2
SWITCH_NUMBER=1
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FCW2014B14T
TAN_NUM=68-100472-02
TAN_REVISION_NUMBER=A0
Uz=Ï kl-Fzvq“D>C0e„Õ
VERSION_ID=V04
[v=¤DT퀦�Ë�ö
boot=usbflash1:c2960x-universalk9-mz.150-2a.EX5.bin
dRY=áê�òT¹e³A“³ÖPi!ð€Pî8©ÜßLF©�è²…,]’RßCíˤ,¢F‘Á!RhxŽè”܉ªp®Òc)0i5&ć ¬še…Ïg„ƼGhYY�_t
m=o5)ÉÌŽç‡áÞæ2ôÔþ|¯
-- MORE --
u=
x=îÛªërí;<ýSi‘7$C
Any help please so i can restore my switch to boot normally
