Packet Injection
Hi All,
can someone explain about packet injection (layer 2 and 3) idea and use case? i searched i different forms and didn't got a clear idea.
thanks in advance
GK
Good luck
KB
Mark Malone
Good explanation of it from a link below , if you look at youtube you can see users demonstrating packet injection attacks in wifi too
What is packet injection?
Forging packets or spoofing packets are common ways of describing packet injection. Packet injection is one way hackers try to disrupt or intercept packets from already established network connections. The way they do this is by injecting their own packets into the data stream. The packets injected by the hacker will appear as normal packets. This causes malicious activity to be overlooked and ignored. Packet injection is used mostly in denial-of-service (DoS) and man-in-the-middle attacks.
https://www.oreilly.com/library/view/applied-network-security/9781786466273/30f87c7a-d5cb-448e-ae8e-fcf57dc8e624.xhtml
