Packet Loss between VLANS
metuckness
Hi all,
I have a C2970 Switch and I am having some real bad packet loss. I finally moved some network devices from VLAN1 to VLAN20 and now I am getting very bad packet loss from items outside of VLAN20.
I configured two ports to VLAN20 and the rest are on VLAN1. I am getting very bad packet loss between devices on the two different VLANS, but none between devices on the same VLAN20.
So, devices on port 22, 21, 20, et cetera (VLAN1) pinging devices on port 3 (VLAN20) are getting this:
Reply from 192.168.20.5: bytes=32 time=37ms TTL=63
Reply from 192.168.20.5: bytes=32 time=35ms TTL=63
Reply from 192.168.20.5: bytes=32 time=26ms TTL=63
Reply from 192.168.20.5: bytes=32 time=19ms TTL=63
Reply from 192.168.20.5: bytes=32 time=4ms TTL=63
Reply from 192.168.20.5: bytes=32 time=2ms TTL=63
Reply from 192.168.20.5: bytes=32 time=5ms TTL=63
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.20.5: bytes=32 time=3ms TTL=63
Reply from 192.168.20.5: bytes=32 time=10ms TTL=63
Reply from 192.168.20.5: bytes=32 time=15ms TTL=63
Reply from 192.168.20.5: bytes=32 time=18ms TTL=63
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.20.5: bytes=32 time=23ms TTL=63
Reply from 192.168.20.5: bytes=32 time=16ms TTL=63
Reply from 192.168.20.5: bytes=32 time=1ms TTL=63
Reply from 192.168.20.5: bytes=32 time=34ms TTL=63
Reply from 192.168.20.5: bytes=32 time=31ms TTL=63
Reply from 192.168.20.5: bytes=32 time=8ms TTL=63
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.20.5: bytes=32 time=30ms TTL=63
Reply from 192.168.20.5: bytes=32 time=6ms TTL=63
Reply from 192.168.20.5: bytes=32 time=27ms TTL=63
Devices on port 4 (VLAN20) pinging devices on port 3 (VLAN20) are getting no packet loss.
Here is my switch config, I am hoping someone can find a config issue that would be the cause of this. I have changed cables et cetera to confirm it wasn't a hardware issue (at least on the cable; devices ports).
C2970#sh run
Building configuration...
Current configuration : 5566 bytes
! Last configuration change at 09:12:38 MST Mon Mar 3 2014
! NVRAM config last updated at 09:12:49 MST Mon Mar 3 2014
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname C2970
boot-start-marker
boot-end-marker
enable secret REDACTED
username REDACTED
username REDACTED
aaa new-model
aaa session-id common
clock timezone MST -7
system mtu routing 1500
ip subnet-zero
ip domain-lookup source-interface GigabitEthernet0/22
ip domain-name internal.int
ip name-server 192.168.1.2
password encryption aes
crypto pki trustpoint TP-self-signed-1551050880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1551050880
revocation-check none
rsakeypair TP-self-signed-1551050880
crypto pki certificate chain TP-self-signed-1551050880
certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353531 30353038 3830301E 170D3933 30333031 30303031
  32305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35353130
  35303838 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DFD8 D9E0510E 6B01916F 1FB2E137 DD4589A9 B0811694 C0547F4D 4A7F7F59
  37D96387 C2A59577 4F6DA108 5B1BC0EA F52EB656 4EB0FE60 1941308D 4F9B3AD9
  257190AA E7574BD7 BF45EEEF EF8FEF00 A4028694 2AE22AB7 B76E9AA3 D16278E8
  2A757A06 D58B1E4E 7A441369 304BE9CE E1513096 4C258796 3863757E 76C042E8
  39ED0203 010001A3 74307230 0F060355 1D130101 FF040530 030101FF 301F0603
  551D1104 18301682 14433239 37302E6D 616C6164 6F6D696E 692E696E 74301F06
  03551D23 00000000 80140D57 3D3AAFCA B4A0BB44 8E48207F 7FF9099A C0F1301D
  0603551D 0E041604 140D573D 3AAFCAB4 A0BB448E 48207F7F F9099AC0 F1300D06
  092A8648 86F70D01 01040500 03818100 53AB91E3 DD31CE2D 78523C46 D92E41D1
  C9C1F831 21CBD887 7F429BF5 E092B794 718E93B0 304EE2DD 110DD53B 278E6081
  FCE47A4C CE959AD2 02030C82 0182D800 2FC3D5C7 4A1F9248 FDF1BBA7 268BB8BA
  B20B95DE C71E784A 3646668A 1006BE67 4F145B9D 408C482D 3638619E CB9CE11A
  537F53F9 DE36C1A4 FBCEFAA1 3EA746DB
  quit
spanning-tree mode pvst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 5
ip ssh version 2
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/3
switchport access vlan 20
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description CONNECTION TO 2811 ROUTER - TRUNK
switchport trunk allowed vlan 1,10,20
switchport mode trunk
interface Vlan1
ip address 192.168.1.3 255.255.255.0
ip helper-address 192.168.1.2
no ip route-cache
interface Vlan10
ip address 192.168.10.3 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.20.1 255.255.255.0
no ip route-cache
ip default-gateway 10.10.1.2
no ip http server
ip http authentication local
ip http secure-server
access-list 1 permit any
control-plane
line con 0
exec-timeout 0 0
password REDACTED
transport preferred ssh
line vty 0 4
exec-timeout 0 0
password REDACTED
transport input ssh
line vty 5 15
exec-timeout 0 0
password REDACTED
transport input ssh
ntp clock-period 36029640
ntp source GigabitEthernet0/22
ntp server 192.168.1.1
ntp peer 192.168.1.2
ntp server 96.226.242.9
end
No there is a router connected to port 24. Do you have sub interfaces configured on that router? If so, what are the ip addresses? You cannot have the same ip addresses configured on the switch svis as you do on the router sub-interfaces.
14 Replies 14
Jeff Van Houten
Level 5
Level 5
Do you have sub-interfaces defined on the router port? If so, do you have the same addresses as on those svi interfaces?
Yes:
interface Vlan1
no ip route-cache
interface Vlan10
no ip route-cache
interface Vlan20
no ip route-cache
glen.grant
  If the router is doing the routing for those vlans you don't need all those SVI's configured on the 2970. You only need a single SVI defined to manage the switch along with the correct default gateway address.
The router has them as well, but I always give routers a .1 IP and switches a .3 address:
interface FastEthernet0/0
description CONNECTION TO INSIDE INT. OF ASA
ip address 10.10.1.2 255.255.255.252
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
description VLAN 10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/1.2
description VLAN 20
encapsulation dot1Q 20
interface FastEthernet0/1.3
description Trunk Interface VLAN 1
encapsulation dot1Q 1 native
ip default-gateway 10.10.1.1
I am beginning to think it is a VLAN issues on the wireless AP that is attached to the ports. I have a WRT300N running  DD-WRT that I use as an Access Point for the wireless devices that I wun on the VLAN20 and it was the AP and the devices behind the AP that were having issues.
I did some testing last night and once I moved the AP back to VLAN1 it worked, no packet loss. So, I think I have to try and figure out how to configure the VLANS on the DD-WRT router. Which is going to be a nightmare because they are nothing like Ciscos AND I just read that they don't go up to VLANS higher than 15. So I am going to have to put the wireless network on VLAN10 or make a new one.
http://www.dd-wrt.com/wiki/index.php/Switched_Ports
Thank you all for checking, but I think that is my problem, it's not tagging the packets that it is passing properly, hence the constant and severe packet loss.
I have asked on the DD-WRT forums if they think that is what it could be and how I might configure the VLANS for VLAN10.
Jeff Van Houten
Level 5
Level 5
Thank you for pulling what I like to refer to as a "Paul Harvey".
LOL, now I have to figure out what a Paul Harvey is!
Really, i didn't think that changing the VLAn the AP was on would be impacted by VLANS, honestly! I was up until 3Am trying to figure this out gimme a little break!
I do appreciate the help. I honestly thought it was something wrong with the switch. At first I thought it was a bad port, then cable, then config, then I started looking at the AP...
I guess I'm giving away my age but In the U.S. For decades there was a syndicated radio host named Paul Harvey. He was famous for telling stories that lead up to a dramatic conclusion that was generally not discernible until the last sentence or two. He would always conclude the lesson of the day with, "And now you know the rest of the story".
Haha. yeah I Googled him. I had never listened to him, but I did hear his famous speech about social and moral decay and the Devil; which I thought was pretty accurate.
I really am sorry, but if you do read that link and are able to tell me how to create and assign VLAN10 to a port using that DD-WRT software that would be fantastic! . I know it's not Cisco related, but I just learned how to setup Cisco devices and then I find something totally different! And their GUI doesn't work, so it all has to be done command line, which is fine, except I don't normally use CLI on DD-WRT devices; their GUI always worked well enough.
The router has Gig ports, so it would follow the Gig examples they show.
But anyway, The only reason I decided that was the issues was because I put a laptop on port 4 which was also in the VLAN20 and it never had packet loss, but the AP and devices behind it did. Even though sometimes the AP wouldn't respond, but I could still get to devices behind it.
Thanks all!
Mitch
Vlan tagging occurs at the switch as traffic is received through the port. If you have an access vlan assigned at the port theres no reason to try to get the ap to tag the packets. I would suggest you are seeing a problem with the ap or the wireless devices behind the ap.
I thought that at first as well, but they work perfect when they are on VLAN1. No packet loss, no drops, nothing. Absolutely flawless like they are supposed to. but i move it to another VLAN and then they start dropping packets.
And it is weird. The AP will stop responding to pings, but the AP devices will continue. Then sometimes all stop, and visa-versa.
But put them on VLAN1 ports and they work fine.
Jeff Van Houten
Level 5
Level 5
I don't have any experience with dd-wrt hacked aps, but I have seen something similar. Years ago I ran across some dell laptops that wouldn't communicate with a Cisco switch on anything other than vlan 1. Updated drivers alleviated most of the problem there. Right now we have issues with the administrative interface on some video DVR devices. They work fine on the cheapest dlink switch around, but absolutely will not work on a Cisco switch port. I suspect drivers there as well.
You might try to turn off dtp with "switchport nonegotiate" pointing to the ap and see if that gets you somewhere.
I will try that tonight and see if it helps. I am also going to mess around with the tagging on the AP and see if I can figure it out, it's the only logical thing that can be the cause of the packet loss that I can think of considering how it has acted.
DD-WRT is great for the routers they have versions for. It adds tons of features the default firmware doesn't do, including VPN's, NAS support, iptables, SSH et cetera.
It's just figuring out how they work
It's so good and populare, Buffalo has came out with a few models that ship with DD-WRT already on them. They just annouced it.
http://www.buffalotech.com/about-buffalo/news-and-press/press-releases/buffalo-introduces-open-source-dd-wrt-wireless-networking-solutions
http://smile.amazon.com/gp/product/B00I2N6O0W/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
