When IP Loopback as multicast anchor point
sugatada9
When IP Loopback address is configured as IP multicast anchor point? I am configuring a Cisco 4500E series switch.
Jon Marshall
Not clear on what you are asking.
If you are using PIM sparse mode then you need to configure an RP and Cisco recommend using a loopback IP address for this.
If you are using PIM dense mode there is no need for an RP.
Jon
Hi John,
I was checking the config of the old switch before create the new config.  below config was there:
interface looback1
description IP Multicast anchor point
ip address x.x.x.x x.x.x.x
ip pim sparse-dense-mode
Do you think the RP is defined here?
Sugata
Yes, i suspect that IP is being used as the RP.
If you do a "sh ip pim rp mapping" that should show you the RP address.
Jon
