Packet Lost (switch 2950 )
pedram rabeti
Hi ,
In my network  (ISP) I have a Catalyst 2950 switch . At one of the switch port I have  packet lost very much . When check log and detail on configuration everything ok and other switch port work well .
It is interesting when look at activity  LEDs on ports , The port with problem ( packet lost) Turns off for a second . (5 sec on 1 sec off ).
When the activity LED off ihave packet lost on port . Two other ports are synchronized such behavior .
In the meantime I get on another port very much pause input :
 0 input errors, 0 CRC, 0 frame, 0 overrun, 1859 ignored
     0 watchdog, 872691 multicast, 539855 pause input
     1065529861 packets output, 84095064 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
A short movie  of problem on youtube :
For best view wait until video loading completely
https://www.youtube.com/watch?v=eUl4ifveh74&feature=youtu.be
Please help me to solve the problem .
Thank you
Even keeping with a 99.999% uptime promise you still have a few minutes you can steel for the swap.  You only have one shot at it though :-)
- Be sure to rate all helpful posts
6 Replies 6
Reza Sharifi
Try connecting a deferent device to this port, if the issue is still the same try upgrading the IOS, if not you may have a hardware issue.
Hi ,
This port link to very important gateway and i cant change port to different devices even for a Minute . IOS is last version !!
Thank you
Hitesh Vinzoda
Level 4
Level 4
Hi  there,
Can you post the show int output of the interface in question.
thanks
Hitesh
Hi ,
yes sure
output command of interface :
FastEthernet0/18 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000e.3825.1c52 (bia 000e.3825.1c52)
  Description:  Link
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 59/255, rxload 10/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 100BaseTX
  input flow-control is unsupported output flow-control is unsupported
  Last input 00:00:29, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4003000 bits/sec, 2856 packets/sec
  5 minute output rate 23313000 bits/sec, 3096 packets/sec
     575269863 packets input, 1268360484 bytes, 5 no buffer
     Received 1201153 broadcasts (210056 multicast)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 5 ignored
     0 watchdog, 210056 multicast, 0 pause input
     586628225 packets output, 2019606696 bytes, 0 underruns
Parvesh Paliwal
Level 3
Level 3
The reason you may be having packet drops is buffer overflow. By default the cisco switch will stop responding to packets when the receiving end (connected to the error prone switchport) is unable to entertain packets anymore. It does automatically resume the transmission.
if possible try sending traffic to the connected node with some sort of MIM (man in the middle).
Parvesh
