03-05-2021 11:32 PM
hello everyone I am having trouble with the smart home activity in 5.1.1.2 my gateway is not showing any of the iot devices however I had to replace it because the default password and username weren't working so whether that has something to do with it I don't know thanks in advance
Solved! Go to Solution.
10-27-2021 04:49 AM - edited 10-27-2021 04:50 AM
Hello!
I had the same problem and saw a helpful video on YouTube by Cyber Geek. Here's the link:
5.1.1.2 Packet Tracer Adding IoT devices to Smart Homes | usernname/password admin | Problem Fixed!
Summary:
He had an error logging in the home gateway (which I also had and I tried replacing the home gateway device with a new one. It fixed the login problem but no iot devices were being shown).
What he did was go to tablet > Programming tab > Run both com.cisco.mqttbroker and com.cisco.mqttclient
I have version 8 and it worked but I had to save first then reload the file.
Not sure why it's like that, though. If anyone has any idea, please let us know.
03-06-2021 12:11 AM
when I open your file in the latest version of Packet Tracer (8), it get a warning saying that some IoT devices are outdated, and the system asks me if I want to update these devices. Which version are you using, and which IoT devices can you not see ?
If you are not using version 8, try and update, and check if everything is visible then...
03-06-2021 11:53 PM
hi Georg am using version 8.0 and I clicked update when that notification pops up i also tried clicking no however it didn't work
03-07-2021 12:00 AM
Never mind for some reason it worked once I reloaded the saved file not sure why but anyway thanks for taking your time to help me
03-07-2021 12:30 AM
good to hear that it is working !
04-11-2021 03:21 PM
I had the same problem; using PT 8 could not login with admin/admin to Home Gateway.
Tried with PT 7.3 it worked.
It seems the activity problem had to do with some bug in PT 8?
09-16-2021 05:22 PM
It says this pkt file is not compatible this version.
04-27-2021 12:17 PM
It seems, that simple linking lab to the certain PacketTracer version could save a lot of us a lot of problems. The first quiz is also inappropriate in terms of PacketTracer 8 UX. I had to downgrade to 7.3 to make this lab run properly... I expected way more quality from the Cisco...
Hello!
Summary:
