Packet tracer 5.1 and VTP pruning
Reza Rezazadeh
I intended to create a LAN and examine VTP pruning on simulation status, but after set a vtp domain and vlans parameters, I can't run a command "vtp prun".
The core device is 3560-24PS.
When I use "vtp ?" only shows "domain, mode, password , version" parameters description.
please help me to active pruning parameter .
jimmysands73_2
Level 5
Level 5
PT does not support that command. If I understand pruning correct, the only way to manually do it on PT would be to use the switchport trunk allow vlan command for this.
Cheers,
Jimmy
5 Replies 5
jimmysands73_2
Level 5
Level 5
Cheers,
Jimmy
In order to enable VTP Pruning on a switch, the switch must be configured as VTP server (for the VTP domain).
Can you post the output of the "show vtp status" command?
With due respect Rantunes, VTP pruning is not a feature supported in PT.
witch#sh vtp sta
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 255
Number of existing VLANs : 5
VTP Operating Mode : Server
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x7D 0x5A 0xA6 0x0E 0x9A 0x72 0xA0 0x3A
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Local updater ID is 0.0.0.0 (no valid interface found)
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#vtp ?
domain Set the name of the VTP administrative domain.
mode Configure VTP device mode
password Set the password for the VTP administrative domain
version Set the adminstrative domain to VTP version
Switch(config)#set ?
% Unrecognized command
Switch(config)#vtp pruning
% Invalid input detected at '^' marker.
On a Catalyst 3560-24PS it is supported.
switch#sh version
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"
cisco WS-C3560-24PS (PowerPC405)
Model number : WS-C3560-24PS-S
switch#conf t
switch#vtp pruning ?
switch(config)#^Z
You must have a different version of PT...I used 5.1 and 5.2, both show no signs of supporting VTP pruning. You sure you using PT? My image file on PT is c3560-advipservicesk9-mz.122-37.SE1.bin, and whenever I issued the command, it didnt work...
Switch#vtp ?
Switch#conf t
Switch(config)#vtp
