Packet Tracer 7.30 not working with Mac OS high Sierra 10.13.6
When I try to open packet tracer you can see it pop up on the dock and then crash. I have a lab that requires that version when clicking the lab I see the application start and then drop out. The install works without any problems in the same way packet Tracer version 7.22 does and that works without a problem.
Any advice tips or help would be most helpful thank you.
luis_cordova
Hi @duncanwhitelawbrown7795
I have had problems with the new version in my MAC too.
As a tip, I set up a virtual machine (VirtualBox) with Win10 and install the PT for Windows.
Martin L
PT 7.x had lots of problems with MACs; Maortiy of them were fixed in version 7.3
but, if u have issues, contact PT using Help menu to report issue or use netacademy.com
Regards, ML
**Please Rate All Helpful Responses **
