packet tracer help
werelong1
I am quite new here, and I apologize if I have posted this in the wrong place, do be patient with me
I am unable to ping to my router from the pc
I have set up vlans and trunk links across the two switches as well as made subinterfaces of the vlans on the directly connected router.
The routers are able to ping each other, I am able to ping the DHCP server
your PC has an incorrect IP address. Find attached the revised file...
post the zipped Packet Tracer project (.pkt) file here...
I have put it as a DHCP to get an IP address from the DHCP server, does it not work? Also, I would like to be able to ping the pc on the routers as well
