08-02-2020 09:00 AM
Running configuration (Router 1841):
line con 0
login local
line aux 0
line vty 0
access-class 2 in
password 7 08731E1C
login
transport input telnet
line vty 1 4
access-class 2 in
login local
line vty 5 15
access-class 2 in
password 7 08731E1C
login
end
When I connecting the device with telnet, how can I found which line vty is currently using?
Solved! Go to Solution.
08-02-2020 09:06 AM
try this command:
show line
you should see something like this:
* 2 VTY - - - - - 8633 0 0/0 -
* 3 VTY - - - - - 15823 0 0/0 -
In this case VTY line 2 and 3 are being used.
08-02-2020 09:06 AM
try this command:
show line
08-02-2020 09:38 AM
Returns below↓
R1#show line
Tty Line Typ Tx/Rx A Roty AccO AccI Uses Noise Overruns Int
* 0 0 CTY - - - - 0 0 0/0 -
1 1 AUX 9600/9600 - - - - 0 0 0/0 -
* 194 194 VTY - - - 2 17 0 0/0 -
* 195 195 VTY - - - 2 23 0 0/0 -
* 196 196 VTY - - - 2 3 0 0/0 -
197 197 VTY - - - 2 0 0 0/0 -
198 198 VTY - - - 2 0 0 0/0 -
199 199 VTY - - - 2 0 0 0/0 -
200 200 VTY - - - 2 0 0 0/0 -
201 201 VTY - - - 2 0 0 0/0 -
202 202 VTY - - - 2 0 0 0/0 -
203 203 VTY - - - 2 0 0 0/0 -
204 204 VTY - - - 2 0 0 0/0 -
205 205 VTY - - - 2 0 0 0/0 -
206 206 VTY - - - 2 0 0 0/0 -
207 207 VTY - - - 2 0 0 0/0 -
208 208 VTY - - - 2 0 0 0/0 -
209 209 VTY - - - 2 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
2-193
I case I have connected with 3 PCs by telnet.
This appropriated which line vty commands, in the running configuration. (first post)
