Packet Tracer - HSRP over Trunk Ports
pwiscott
I am using PT 7.2.1 and am trying to emulate our 4500 core using 2 3650's. I understand I cannot use VRRP and the likes but was hoping I could use HSRP ?.
I have the 2 3650's trunked together using 2 interfaces and a port channel however HSRP does not seem to work, should it. ?
Mark Malone
I dont use that emulator but looks like it is supported , in what way is it not working , are you not getting standby/active
can you post the config from each switch take a look
on a side note, I don't get an option for HSRP for IPv4 on a port channel interface on the 3650, so it doesn't seem to be supported on that device:
Switch#conf t
Switch(config)#ip routing
Switch(config)#interface port-channel 1
Switch(config-if)#standby 1 ?
ipv6 Enable HSRP IPv6
Shut down PT and start back up and launch scenario and it works !!
Core_2#sh standby
Vlan41 - Group 41
State is Active
6 state changes, last state change 00:00:28
Virtual IP address is 10.50.41.1
Active virtual MAC address is 0000.0C07.AC29
Local virtual MAC address is 0000.0C07.AC29 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.678 secs
Preemption enabled
Active router is local
Standby router is 10.50.41.2
Priority 115 (configured 115)
Group name is hsrp-Vl4-41 (default)
Vlan42 - Group 42
State is Active
4 state changes, last state change 00:00:18
Virtual IP address is 10.50.42.1
Active virtual MAC address is 0000.0C07.AC2A
Local virtual MAC address is 0000.0C07.AC2A (v1 default)
Next hello sent in 1.92 secs
Preemption enabled
Standby router is 10.50.42.2
Group name is hsrp-Vl4-42 (default)
emulators can always be a bit buggy :)
