Port channel unassigned
I have a portchannel that is not coming up. I shows unassigned. Here is the relevant port configuration and output of the status
Core-1#sh run int g9/21
interface GigabitEthernet9/21
description CHANNEL to Stack-1 G1/1/1
switchport
switchport trunk native vlan 2
switchport mode trunk
channel-protocol lacp
channel-group 10 mode active
end
Core-1#sh run int g10/21
interface GigabitEthernet10/21
description CHANNEL to Stack-1 G1/1/2
switchport
Core-1#sh run int po10
interface Port-channel10
description CHANNEL to Stack-1 G1/1/1 G1/1/2
switchport
end
Core-1#sh etherc sum
10 Po10(SD) LACP Gi9/21(I) Gi10/21(I)
Po10 CHANNEL to Stack-1 notconnect unassigne auto auto
Hello
Remove the channel-protocol feature and recreate the port-channel using just channel-group x mode x and test again, also make sure the other side of  the etherhannel is compatible
Kind Regards
Paul
balaji.bandi
As your Output
10 Po10(SD) LACP Gi9/21(I) Gi10/21(I)  - show as individual other side.
Can you post other side config also model of both the switches ? and Version running.
BB
I suppose I was having a momentary lapse of reason. I failed to complete configuration on the other side. -1 for multitasking, the human brain can only focus on one thing at a time.
luis_cordova
Hello
Kind Regards
Paul
