Packet Tracer Question
dalbright1
I just found Packet Tracer today and it's a great tool to help me study. But one of the first things I noticed is I cannot do a show run int xxxxx command. I thought perhaps it was a IOS version issue so I did the upgrade to version 15 and still a no-go.
This would be extremely helpful as I get a more complex configuration going. any ideas why it doesn't work or how to get it to work?
Jaderson Pessoa
No, its doesn`t work on packet tracert. Some features dont works well on packet tracer. Otherwise, you can use other features, like EVE-NG, GNS3 or VIRL.
EVE-NG: https://www.eve-ng.net/downloads
GNS3: https://www.gns3.com/
VIRL: https://dcloud.cisco.com/
Best regards
Rate all post that were help you.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
Best regards
Jaderson Pessoa
Hi @dalbright1 ,
In PacketTracer, to see the settings in an interface you can use these commands:
#show running-config
#show ip interface brief
#show ip interface gigabitEthernet 0/0
#show interfaces gigabitEthernet 0/0
