Packet tracer SW3560 static routing not working
nuggetinu
I am just trying some VLAN routing using the 3560 switches in packet tracer. I have created a vlan 4 on switch A with vlan interface being 10.0.0.254 and vlan 5 on switch B with vlan interface being 172.16.1.254. A layer 3 trunk has been established, on switch A fa0/2 192.168.1.1 and on switch B fa0/2 192.168.1.2.
To enable communciation between the 2 PC on different VLANS i have tried performing the below static routes which are showing in the running config but not in the show ip route results. Also, 192.168.1.1 is able to ping 192.168.1.2.
SWA - ip route 10.0.0.0 255.255.255.0 192.168.1.2
SWB - ip route 172.16.1.0 255.255.255.0 192.168.1.1
I also tried through the interfaces to no avail.
SWA - ip route 10.0.0.0 255.255.255.0 fa0/2
SWB - ip route 172.16.1.0 255.255.255.0 fa0/2
The PCs are only able to communicate through default routes set on each switch, i.e
SWA - ip route 0.0.0.0 0.0.0.0 192.168.1.2
SWB - ip route 0.0.0.0 0.0.0.0 192.168.1.1
I am attaching the packet tracer file for your perusal. Why are the normal static routes not being applied/working? Thanks for the help
your static routes are misconfigured. Add the below:
DLS1(config)#ip route 172.16.1.0 255.255.255.0 FastEthernet 0/2
DLS2(config)# ip route 10.0.0.0 255.255.255.0 FastEthernet 0/2
The .pkt file contains an empty project. Best to save the file as .pkt, then rename it to .jpg and post it...
just did. Thanks!
my bad! Thanks!
