Packets with COS tags espaping our COS maps
Background. 4 switch 3750 stack. Switch #4 is the master.
We have the following QoS cos-maps setup on our switch.
mls qos srr-queue output cos-map queue 2 threshold 1 2 3 4 6 7
mls qos srr-queue output cos-map queue 2 threshold 3 1
mls qos srr-queue output cos-map queue 3 threshold 3 0
by this definition anything with a COS of 1,2,3,4,6,7 should go into Queue 2 and anything with a COS of 1 should go into queue 3.
The switch uplink is set to trust DSCP. Here are our DSCP to COS maps and COS to DSCP.
Dscp-cos map:
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 40 48 56
Somehow we are experiencing drops on Queue 1 however.
switch#remote command 1 show platform port-asic stats drop fastethernet 1/0/24
Switch : 1 :
Interface Fa1/0/24 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 547384
Weight 1 Frames 100
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 633
This is only incrementing when the user is actively using a video system called XOS. How/Why are packets getting mapped into queue 1 given our cos maps?
cisco_lad2004
Level 5
Level 5
Lance,
Your config is actually doing the following:
COS 2,3,4,6 & 7 to Q2
COS 1 to Q2
COS 0 to Q3
If too many packets are queued on Q2, there will be drops.
How is Video traffic marked, COS5 / DSCP 40-47 ?
Sam
True, true on the cos-map breakdown. Anything with a COS of 2,3,4,6,and 7, should also be dropped at threshold 1 in queueu 2 and anything with COS of 1 should be dropped at threshold 3 in queue 2.
We don't have a cos-map for COS 5. Maybe this is the problem. How can you tell what the default queue is if no cos-map is specified.
"sh mls qos maps cos-output-q" will confirm that Q1 is ur priority Q and mapped to COS5.
Typically this Q is policed so it does not starve the other Qs. so one way to validate if this indeed your problem, try remarking Video traffic at edge to another available Q that is not over used.
Sam
