pagp dual-active for VSS on 3750
serge123
Hi all,
Do I need to be connected to VSS switch to see if my switch supports dual-active pagp?
Should I be able to use this 3750 for dual-active detection?
thank you.
INFO:
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750-48TS      12.2(46)SE            C3750-IPSERVICES-M
Switch#        sh pagp dual-active
PAgP dual-active detection enabled: Yes
PAgP dual-active version: 1.1
Channel group 3
          Dual-Active     Partner              Partner   Partner
Port      Detect Capable  Name                 Port      Version
Gi1/0/1   No              None                 None      N/A
Gi1/0/3   No              None                 None      N/A
Switch#
From what I can read here this 3750 should support dual-active detection
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-releases-12-2-special-early-deployments/product_bulletin_c25-493554.html
Reza Sharifi
Yes, that is correct.  You can use the 3750 for dual active detection.
Reza Sharifi
thank you Reza
