PAP authentication in PPP
fjcardenas-1
I read that for configuring PAP authentication in a serial PPP link we need the following commands. I am using R1 and R2 as example:
In R1:
username (R2) passsword (word) - Global command.
encapsulation ppp (int subcommand)
ppp authentication pap (int subcomand)
The same commands in R2 but configuring the username as R1.
Once I enter the "ppp authentication pap" command the link goes down.... is there any reason for this behavior? Is there any crazy thing like needing the cable to be unplugged before setting the configuration and plugged back once the configuration is done?
This is my configuration in R1:
username R2 password 0 carro
interface Serial0/0
ip address 12.0.0.1 255.255.255.252
encapsulation ppp
no fair-queue
Help please to understand why... I am doing what the book says.
Edison Ortiz
You need to send the username and password with the following command:
On R1:
ppp pap sent-username R1 password carro
On R2:
ppp pap sent-username R2 password carro
5 Replies 5
Istvan_Rabai
Level 7
Level 7
Hi Francisco,
R2 configuration should be the following:
username R1 password 0 carro
interface Serial0/0
ip address 12.0.0.2 255.255.255.252
encapsulation ppp
Did you configue this on R2 ?
Cheers:
Istvan
Yes, that is the configuration in R2... but it doesn't work... the connection fails once I enter the "ppp authentication pap" command on either end.
OK. But you have to enter "ppp authentication pap" on both ends.
Use "debug ppp authentication" to see what is happening.
Cheers:
Istvan
Edison Ortiz
On R1:
On R2:
Hi Edison,
You're right, I forgot about this.
Thanks for your contribution.
Istvan
